Hi together,
CAESES can be used for designing a variety of turbomachinery and engine components (impellers, volutes, ducts, axial blades,...). I have attached some pictures and animations, just to give you an idea of the applications. There is also a page about the turbomachinery industry on the CAESES website. Check out the blog where turbomachinery design stories get posted on a regular basis (most of the attached pictures are taken from these blog posts).
The focus of CAESES is: Fast and efficient design studies and CFD-driven shape optimization.
The robust variation (manual/automated) of turbomachinery components is really the interesting part in CAESES. The geometry models are typically highly customized, i.e., company-specific know-how can be fully integrated. There is an internal scripting environment to define custom methods and processes. Complex parametric models can be wrapped into an easy-to-use interface (so that they can be readily used by non-experts of CAESES).
Parametric support geometry such as segments for the flow and structural analysis can be part of the model, too. post-8-0-59808400-1519381616_thumb.png
As a side note, you can optionally plug-in your CFD tool and run optimizations right away - from within the CAESES GUI. There are integrated optimization methods and some handy post-processing capabilities. Alternatively, you can use your own optimization tools and run CAESES in batch mode.
There are free academic versions of the CAESES pro edition for students and PhD students, as well as trial licenses with flexible time frames. There are also special editions for small companies, start-ups and freelancers.
Hope this helps,
LAST UPDATE FEBRUARY 2018
