Mr. Simone Bigalli 0 Report post Posted February 6, 2019 Hi,I have a question about the edge fillet operation inside the BReps functions. Working with CAESES I noted the possibility to obtain general fillets between two given surfaces using two different options:- All edges- Fillet between colored faces While for simple surfaces I'm able to achieve the desired fillet using the first option (All edges), I have some problems to obtain the same result using the second one (Fillet between colored faces). In other words I don't understand how to use correctly the edge fillet operation by means of the option "Fillet between colored faces". To explain my question I attached a simple example; could someone explain me how to resolve this problem? Moreover, I would like to know if CAESES offers other options to quickly obtain general fillets between two given surfaces. Thank tou very much.Cheers. SimoneFillet_Prove.fdbc Share this post Link to post Share on other sites
Ceyhan Erdem 15 Report post Posted February 6, 2019 Hi Simone, Please find the attached the project where the fillet creation wrt colored faces is performed. Do not forget that in CAESES, colors can be assigned within BRep for each operation. So I have created an operation "add sources" where a color is assigned to first face (let's say first_face_color),then a second "add source" operation; adding the second face and assigning a color (let's say second_face_color) Finally I can perform the fillet operation between the two colors (first_face_color, second_face_color) Please let me know if you have further questions. CheersCeyhanFillet_Prove.fdbc Share this post Link to post Share on other sites
Jörg 29 Report post Posted February 6, 2019 Hi Simone, In many cases the fillet is created during operations, e.g. you apply a Boolean operation between two solid bodies and then configure the fillet within the operation itself: You can find this example in the shipped version of CAESES (documentation browser => basics > general > breps). Share this post Link to post Share on other sites
Mr. Simone Bigalli 0 Report post Posted February 6, 2019 Hi Ceyhan and Joerg,thank you very much for your kind reply that allowed me to better understand how to achieve fillet edge between two general surfaces. Cheers. Simone Share this post Link to post Share on other sites
Mr. Simone Bigalli 0 Report post Posted February 11, 2019 Hi Ceyhan and Joerg,I have anoher question: using the BReps functions and the approach "Fillet between colored faces" is it possible to achieve fillet edges with not constant fillet radius (i.e. with a fillet radius that starts to zero and increase its value linearly)?I noted there is the possibility to manage this aspect changing the "Type" option in the "Filleting" panel (i.e. selecting "constant distance" or "variable radius" instead of "constant radius") but I don't understand how to use these two different approaches. Thank you very much.Cheers. Simone Share this post Link to post Share on other sites
Ceyhan Erdem 15 Report post Posted February 12, 2019 Hi Simone, Please check the sketches below, This might give you an idea about the concepts of constant radius and constant distance. For variable radius, Please check the attached project. One point to mention is that the variable radius filleting is still under development. Please let me know if you have further questions. CheersCeyhanfillet.fdb Share this post Link to post Share on other sites
Mr. Simone Bigalli 0 Report post Posted February 12, 2019 Hi Ceyhan,thank you very much for your reply. Cheers.Simone Share this post Link to post Share on other sites
