Mr. Suraj Pawar 0 Report post Posted May 15, 2018 I am trying to optimize the propeller geometry. I came across a paper "An Optimization Process for Propeller Design and its Application Based on CFD" which uses CAESES and StarCCM+ for optimization. I would like to know if there are any tutorials on Sobol sequence? How exactly does Sobol sequence works? Does the Sobol algorithm generates sequence of n points uniformly distributed in a space at the beginning? Or does the sequence of n points depends on CFD simulation results on previous iteration? Thank you. Share this post Link to post Share on other sites
Mr. Mattia Brenner 6 Report post Posted May 15, 2018 Hi Suraj, the Sobol sequence is not dependent from previous CFD results. Hence, all designs of a Sobol study can be generated at the beginning and computed afterwards. See also this: https://en.wikipedia.org/wiki/Sobol_sequence Cheers,Mattia Share this post Link to post Share on other sites
Mr. Suraj Pawar 0 Report post Posted May 15, 2018 Hello Mattia, Is there any I can save .step file of all the geometries created by Sobol sequence? I can view all geometry variants in design viewer. How can I export all the possible geometries? Thanks. Best Regards,Suraj Pawar Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted May 16, 2018 Hi Suraj, When you run any optimization sequence, the geometry for each new design will be automatically saved in the corresponding folder structure with respect to the export type defined previously in the Software Connector phase. Say you are running a Sobol sequence; let's say the first created sobol sequence is Sobol_01Within your CAESES project folder, In the folder;01_sobol / Sobol_01_des0000 <depending on the design, let's pick the first one> /Runner You will find the geometry that you are seeking for. CheersCeyhan Share this post Link to post Share on other sites
Mr. Suraj Pawar 0 Report post Posted May 17, 2018 Hello Ceyhan, I have created a software connector. But currently I am not using external software. I am interested only in getting the geometry in .step format and not run the whole optimization in CAESES framework. I can run the sobol sequence and it generates 10 geometries. I am having two problems:1. I can not view all the designs in design viewer2. When I run the connector 01_sobol / Sobol_01_des0000 <depending on the design, let's pick the first one>/Runner folder is not created. Can you please take a look into the attached file to see what is the mistake that I am doing. Thank you very much. propeller_PD=0.8_highTipThickness.zip Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted May 22, 2018 Hi Suraj, 2) Please use the command below, [03_solid|Propeller.exportStarCcmPlusStep(getDesignDir() + "/propeller.step")] Because you have not assigned any Software Connector; no geometry will be exported unless you specify explicitly. You have to use this command in your Design Engine's "Design Pre/Postprocessing" menu, under the Postprocessing Commands. So after the creation of each new design, the command to export the geometry to the relevant Design Directory will be executed. 1) In your setup, there was no objective assigned. Please review the attached project and the picture. CheersCeyhanpropeller_PD_0.8_highTipThickness.fdbc.tar.gz Share this post Link to post Share on other sites
Mr. Suraj Pawar 0 Report post Posted June 22, 2018 Hello Ceyhan, I was able to export the step file of the geometry created in Caeses. I would like to know if it is possible to have different name given to each of the exported step file. For example this command [03_solid|Propeller.exportStarCcmPlusStep(getDesignDir() + "/propeller.step")] will save each file as propeller.step. How can I have different names for each geometry. Thank You. Share this post Link to post Share on other sites
Jörg 29 Report post Posted June 28, 2018 Hi Suraj, You can try to create a string parameter (CAD > parameters > string parameter) which is an expression of the design ID or name (e.g. getCurrentDesign().getName()) and the base name (e.g. propeller_design_001.stp). This parameter can then be set as input for the post-processing commands, together with the design dir expression etc. No limits :-) 1 Share this post Link to post Share on other sites
