Ms. lexi wang__0001 0 Report post Posted April 23, 2018 Hi, I am now trying to export a fully parametric model to rhino. But i have got lots of NURBS surfaces . ( Since we are doing some comparison work for T-spline in rhino and NURBS in caeses ) 1.How can I directly export the surfaces from caeses to rhino? 2.when I export the local parametric bulb from caeses with stl.file to rhino that is fine. Is this about the fully parametric model ? 3.Recently when I open the files i have got some tips on the model like in figure. question , How can I repair them? 4.When I am trying to get the shaft_cut_tan in the figure.question2. I cannot make the start and end point for Y=0, that is why i cannot close the shaft totally. How can I repair this problem? Thanks for your help! Lexi. Share this post Link to post Share on other sites
Ceyhan Erdem 15 Report post Posted April 24, 2018 Hi Lexi, Is it possible that you share the project file if it is not confidential?You can send the fdb/fdbc file to erdem@friendship-systems.com, so I can give a look. CheersCeyhan 1 Share this post Link to post Share on other sites
Jörg 29 Report post Posted April 25, 2018 Not sure what you mean. If you export the model using IGES or STEP, of course you will get all the surfaces that you have created within CAESES. Which export format did you use? Not sure what you mean. Is this a new behavior? For example, did it work with a previous CAESES version so that it is a compatibility issue? 1 Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 25, 2018 1 I have a fully parametric model, i wanna export igs.file with surfaces to RHINO2 There is no problem for transporting stl.file to use in starccm3 I think that is always there i will send the team erdem for a check .Thank you for your help! Share this post Link to post Share on other sites
Jörg 29 Report post Posted April 25, 2018 Ok, cool. What is the problem with the IGES file? Usually we have no problems with exporting models to RHINO using the IGES format. I guess the other things are really something where one have to look into it. Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 25, 2018 Hi Lexi, Is it possible that you share the project file if it is not confidential?You can send the fdb/fdbc file to erdem@friendship-systems.com, so I can give a look. CheersCeyhanHi I have send you the file. cheers,Lexi. Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 25, 2018 Ok, cool. What is the problem with the IGES file? Usually we have no problems with exporting models to RHINO using the IGES format. I guess the other things are really something where one have to look into it. I have send Ceyhan the file just now. Thanks for your help!Cheers,Lexi. Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted May 8, 2018 Thanks for all your help, my questions have been solved. :)cheers,lexi. Share this post Link to post Share on other sites
Mr. Wolfgang John__0001 0 Report post Posted June 7, 2018 I have problem too and solved. Thanks you Share this post Link to post Share on other sites
