Mr. Suraj Pawar
Unable to export solid geometry
I have created Marine propulsor geometry using CAESES. The geometry consists of shaft, rotor and stator. I am using Brep feature/ solid from intersection to create solid geometry. But when I export step file or iges file I am not able to get solid geometry. I only get surface geometry. I have attached the project file.
Thank you.
marine_propulsor.zip
Hi Suraj,
From what I can see there are a couple of files missing to make this project run. You can also use commands such as
resolveEnv("$PROJECTDIR") + "/naca0010TE.txt"
to have a relative path definition. Makes it easier for others (and maybe also for yourself) to let it run on other computers with different directory paths. Just as a side note.
Hi Suraj,
After some checks on the created stator blades I have figured out that the distribution of the control points on the created airfoil curve was changing drastically at some point.
This was creating a problematic surface that might lead to failed solid creation.
The bug is already solved in the new version which will be released soon. Meanwhile I can provide you a workaround.
Please find attached the project file with the updated feature definition.
Note: please update the thickness file path in the feature definition accordingly
Ceyhan
propulsor_v2.fdbc.tar.gz
