Mr. Suraj Pawar
Fit profile point data with LE and TE
I am trying to use the feature "Fit profile data with LE and TE". I have set of points and LE and TE curve in the form of circle. When I try to use this feature it creates NURBS curve and there is an error in creating this NURBS curve. i am not able to figure out what that error is. I have attached the file.
Thank you.
nacaprofile_trial.fdbc
Hi Mr Suraj Pawar,
From the picture you have attached I can see that a curve is assigned for point data.
Instead of a curve a set of points should have been assigned
Please see the attached picture.
Ceyhan
Hi Suraj,
It is a bit difficult without any point data to reproduce your problem. Maybe the point data does not "naturally" fit to the given circles (e.g. too large diameters). Can you try to remove the first and last point of your point data? This could work if I look at your picture.
