Hi!
I'm wondering whether it's possible to insert a quad/plane textured with image? Also, image contains coordinate system which I would like to calibrate to Caeses units and then I would draw curves snapped on that plane over the image. I'd actually like to draw a ship hull from its lines drawing, and then loft or whatever to recover the full shape.
J.Basic
Hey Josip,
I've done something similar a couple of month ago.
Images can be visualized with the glpictureframe object (menu> Visualisation > Glpictureframe)
When you have visualized your linesplane you can start to create your sections with points and lines.
In this example I have used a bsplinesurface and fitted it to the linesplan.
Move the base position points to place the pictures.
You can create curves and create a lofted surface from these curves.
Here is another post which gives more inside about the picture frame.
If you have any further questions do not hesitate to ask.
dufour_002.fdb
Hello Mr. Wenzke, the video  "Adding a bulbous bow to ship without bulb" uses a curve generated from a image surface,  command Features/ HullDesign/isomapping is from latest  Caeses version? I don't see this in my GUI.
