liuxuyang
Problems of design variables in the optimization of propeller
When parameterizing the propeller, I chose the Bezier curve. Now, for the camber, there are four control points. In CAESES, the x and y coordinates of each point need to be specified as specific values, which means there are eight design variables for one camber. With six important parameters of the propeller, it's equivalent to having 48 design variables. Is this too many for the optimization process? Are there any specific propeller optimization cases that I can learn from?
HI Liuxuyang,
Did you have a look into our propeller models? If you want to share your model we can give you some advice. You can send it to info [at] friendship-systems.com.
Best Regards
