Mr. Daniel Floden 0 Report post Posted December 12, 2013 Hi, What is the most straight forward way of exporting lines (in xy-plane) to AutoCad? RegardsDaniel Share this post Link to post Share on other sites
Jörg 29 Report post Posted December 12, 2013 Hi Daniel, Currently, we support only a subset of the DXF import. The DXF export is not available so far (but we will check it).With lines you mean e.g. curves in your 3D view, right? As a work around, can you use IGES for this purpose? CheersJoerg Share this post Link to post Share on other sites
Mr. Claus Abt 7 Report post Posted December 12, 2013 Hi Daniel, I tried a converter from PDF to DXF which I found in the web. Seems to work fine and there are a few out there. Maybe as a workaround this is sufficient? PropDrawing.pdfPropDrawing.zip The reimported does not show numbers but I think this is because CAESES / FFW does not support these entities. CheersClaus Share this post Link to post Share on other sites
Mr. Daniel Floden 0 Report post Posted December 16, 2013 Thanks for the info, Iges is the way forward, I thought I tested that but I must have made som error when I exported, but now it works well! Thank you. Pdf to dxf is perfect for the 2s view. Thanks. /Daniel Share this post Link to post Share on other sites
rishab 0 Report post Posted January 28 This is helpful, thanks for sharing. Share this post Link to post Share on other sites
