Can we add extra design variants on top of the existing design variants?
Sobol
4 replies to this topic
#1 Mr. Joseph Jhun
Mr. Joseph Jhun
    Newbie
  • Pip
  • 8 posts
Posted 10 May 2019 - 01:39 PM
Hi Group,
I've generated 20 design variants with Sobol algorithm and finished the entire simulations.
I'm curious whether it's possible to add, say, 10 more design variants on top of the initial 20 design variants or not.
Thanks,
Joseph
#2 Jörg
  • 503 posts
  • LocationBerlin, Germany
Posted 10 May 2019 - 02:10 PM
Hi Joseph,
From your question it is not fully clear to me what your process is. Can you elaborate a little bit more on what you want to do?
#3 Mr. Paulo Macedo
Mr. Paulo Macedo__0002
    Newbie
  • Pip
  • 9 posts
Posted 10 May 2019 - 03:01 PM
Hi Joseph,
From what I understood, you can run another sobol variation which the sequence start index = 20.
This will create another window of results, but you can drag a number of designs from the left window to the previous design results table.
Mvh
Paulo
  • 1
#4 Mr. Joseph Jhun
Mr. Joseph Jhun
    Newbie
  • Pip
  • 8 posts
Posted 10 May 2019 - 03:20 PM
Hi Joerg and Paulo,
Thanks for your quick response.
Paulo, so does that mean we could combine those two Sobol variants together simply by dragging them from one window to another?
Also, if that's the case, wouldn't it compromise the "randomness" of the those two? I'm not convinced yet whether "random + random = random" always or not...
Thanks,
Joseph
#5 Mr. Paulo Macedo
    Newbie
  • Pip
  • 9 posts
Posted 13 May 2019 - 10:20 AM
 Joseph,
When you drag, you just add the variants from different optimization runs to one list of results.
If you maintain the exact same design variables, lower and upper limits, it will just generate more samples starting from index 20, for example.
Should not compromise the randomness.
Also tagged with one or more of these keywords: Sobol
