export result in excel though batch mode
6 replies to this topic
#1 Ms. Haipeng Liu
Ms. Haipeng Liu
    Newbie
  • Pip
  • 6 posts
Posted 11 August 2017 - 10:58 AM
Hi Caeses Team,
I used the batch file to export geometry before. Now I want to export a x value of the point into an excel or text. How could I write this programming command inside the .fsc file?
Many thanks!
#2 Mr. Carsten Fuetterer
  • 145 posts
Posted 11 August 2017 - 11:32 AM
Hi Haipeng,
you have to write a feature inside the project, which writes a file. This can be the code for the feature:
ffile file(getResultsDir()+"/"+filename)
if (!file.openWrite())
  echo("Failed to open file \"" + file.getAbsolutePath() + "\" for writing")
  break()
endif
// use file.write() or file.writeLine() to write to the file.
file.writeLine(""+p:x+"\t"+p:y+"\t"+p:z)
//close file when done with it
file.close()
To write this code I simply used the feature templates.
Then in the fsc script you have to write a line:
exportFile.run()
This will update the feature and trigger the export.
best regards
Carsten
Carsten Fütterer
M.Sc. Energy & Process Engineering
CAE Applications Engineer
www.friendship-systems.com
Tel. +49 (0)331 967 66 28
#3 Jörg
  • 503 posts
  • LocationBerlin, Germany
Posted 11 August 2017 - 11:43 AM
See also this post for more information about how to write a file.
#4 Ms. Haipeng Liu
Ms. Haipeng Liu
    Newbie
  • Pip
  • 6 posts
Posted 14 August 2017 - 11:16 AM
Hi Haipeng,
  break()
endif
file.close()
exportFile.run()
best regards
Carsten
Thanks a lot for your advice. It works well in my project.
#5 Ms. Haipeng Liu
Ms. Haipeng Liu
    Newbie
  • Pip
  • 6 posts
Posted 14 August 2017 - 11:18 AM
Hi Joerg, thanks a lot for your sample. It helps a lot!
#6 Ms. Haipeng Liu
Ms. Haipeng Liu
    Newbie
  • Pip
  • 6 posts
Posted 14 August 2017 - 01:12 PM
Hi Haipeng,
  break()
endif
file.close()
exportFile.run()
best regards
Carsten
Hi Carsten and Joerg,
Is that possible to write the result into an existing excel instead of a new .txt?
#7 Jörg
  • 503 posts
Posted 05 September 2017 - 08:11 AM
Hi Haipeng,
There is the possibility to connect to an Excel sheet through the COM interface. Maybe this helps. However, I am not sure whether the feature in this rather old post still works, maybe you can simply try it out.
