Mr. MAYTHU ZAW 0 Report post Posted February 20, 2017 Hello all,I am a student from korea and just a new user of CAESES.What I want to do is optimization of hull form for resistance and seakeeping.For resistance,I will connect openFoam and CAESES.But for seakeeping,I want to use only 2D strip theory code .So which software can I use to connect with CAESES?Is there anyone who have done this kind of simulation?I need advice and suggestions for this.If there is someone who knows this,please help me. Thank you all. Share this post Link to post Share on other sites
Mr. Simon Broenstrup 1 Report post Posted February 20, 2017 Hi, we have done connections between Maxsurf and CAESES before, so it is definitely possible, but thus far we only used the stability application (former Hydromax). It should be possible to also make a connection to control the motions application. I send you a message with the features we have. Cheers,Simon Share this post Link to post Share on other sites
Mr. Andreas de Gaaij 0 Report post Posted March 27, 2019 Hi,For my study I'm also trying to optimize the seakeeping behavior of a vessel. For this I want to use a 2D strip theory code, like Maxsurf Motion is capable to do. Is there already a connection available between CAESES and Maxsurf? Kind regards,Andreas Share this post Link to post Share on other sites
Ceyhan Erdem 15 Report post Posted March 28, 2019 Hi Andreas, If the mentioned tool that you would like to couple with CAESES has the capability to run script files or run in batch mode, then the connection should be quite straight forward.Please let me know if you need further assistance. I will recommend you to check the Software Connection tutorials within CAESES and the batch scripting commands of "Maxsurf Motion" within its manual. CheersCeyhan Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted March 28, 2019 For Seakeeper you can also connect using the COM-integration.CheersClaus Share this post Link to post Share on other sites
