Mr. Zheng Liu 0 Report post Posted December 9, 2016 Hi, I designed a volute model (see attached files). The volute cross sectional profile seems OK, but whenever I create a meta surface using the curve engine, the geometry seems to have topology problem. I cannot create a BRep geometry based on this meta surface. I do not know what to do, anyone can help me? Many thanks,Zheng volute_problem.fdbc Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted December 9, 2016 The Brep wants to sue the matching start and end edges of the surfaces. If you shorten the volute surface a bit the Brep will be created with no problems. You need to create the tongue area anyway. Depending on you tongue approach just carry on with a trimmed volute surface and create the total volute brep at a later stage. Cheers, Karsten Share this post Link to post Share on other sites
