Hi together,
Please note that CAESES can be utilized as an OpenFOAM GUI (Graphical User Interface).
There are free academic versions of the CAESES pro edition for students and PhD students as well as trial licenses with flexible time frames. There are also special editions for small companies, start-ups and freelancers.
Compared to other tools in the market, CAESES is good at automation, i.e. if you already have an existing OpenFOAM setup and you want to analyze design variants of your product, then CAESES might be a perfect choice. Especially, if geometry variation plays a major role. In contrast to that, a tool such as HELYX-OS might be a better choice e.g. if you would like to set up an OpenFOAM case from scratch.
Here are some CAESES-specific offers:
  • Conveniently configure and manipulate template files (e.g. controlDict or any other ASCII file) in the GUI
  • Change your geometry design and trigger OpenFOAM with a single mouse-click for analysis (i.e. streamline your design process / automation)
  • Use your individual result values such as pressure loss or homogeneity for an objective function in design studies and shape optimizations
  • Postprocess your simulation data (streamlines, contour plots etc)
Here is a video that shows some of the features in CAESES.
LAST UPDATE FEBRUARY 2018
Hey Joerg
This may be due to my lack of understanding of Ubuntu and OpenFOAM, but I have been trying to run the Ahmed Body sample.
The part I have been struggling with is pointing CAESES to an OpenFOAM executable.
I understood that there was no single OpenFOAM program, but that it is a library of utlitlies and solvers?
Do you think you could give me a hint as to what to do next, where to find the OpenFOAM executable or do I point it to the solver executable?
cheers
James
Thanks for your help Matthias
Could not get it to run, below I have copied and pasted the output of the console.
*** INFO computation : preparing generic process ... [design: baseline]
*** INFO computation : writing generic command files ... [design: baseline]
*** INFO computation : generic process prepared [design: baseline]
*** INFO OpenFOAM STL Export : processing [exporting 1 object(s)]
*** INFO computation : running external process [/home/mid/Allrun in design baseline]
*** INFO LocalResourceManager : Updated permissions on external process file /home/mid/Allrun.
*** INFO computation : finished results [design: baseline]
*** INFO FGenIntReader : Could not open file /home/mid/Desktop/ahmedbody/manual_results/baseline/computation///forceCoeffs.dat for reading [parsing process aborted]
*** INFO FResultsGenInt : File read error [Failed to open file /home/mid/Desktop/ahmedbody/manual_results/baseline/computation/case.foam]
Hey Carsten
I found i found the stdouterroroutput.redirect file and have copied it below.
Seems like it cant find where OpenFOAM library is located?
Moving /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//input/0 to /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//0
Moving /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//input/Allrun to /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//Allrun
Moving /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//input/constant to /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//constant
Moving /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//input/system to /home/mid/Desktop/ahmedbody2/manual_results/baseline/computation//system
[Captured output from application /home/mid/Allrun]
./Allrun: 3: .: Can't open /bin/tools/RunFunction
Thanks,
Hi James,
It seems to be a problem of OpenFOAM variable resolving!
Maybe you didn't setup your OpenFOAM environment before starting CAESES-FFW.
To do that:
- you can modify the CAESES-FFW.sh start script and add the following lines in the header (not in the first line, you need the shebang!)
- you can modify your  ~/.bashrc to have the environment settings in all your Terminals(note: you have to run the CAESES-FFW out of a terminal).
- you can  modify your  ~/.profile to have the environment settings for all your applications (even from the Desktop Icon, if you created one)
(-> please read for more details or find a man page for your distribution)
export FOAM_INST_DIR=/data/app/OpenFOAM
foamDotFile=$FOAM_INST_DIR/OpenFOAM-2.1.1/etc/bashrc
[ -f $foamDotFile ] && . $foamDotFile
With that setup you will always "source" (load) the required OpenFOAM environment before starting CAESES-FFW.
Otherwise the line in the script "Allrun" would not be succesful.
. $WM_PROJECT_DIR/bin/tools/RunFunctions
more installation help could be found here:
http://www.openfoam.org/archive/2.1.1/download/source.php
Regards
Konrad
Hello
Im havin problen with openfoam connector.
I have workin isntall of openfoam 221, currently im using helyx os with it, but free version is limited and does not have modelling capabilities.
So CAESES would be berfect for my use, but Im having problem with connectin openfoam, im trying to run ahmedboby sample but im getting this error:
*** INFO Multi Body STL Export : processing [exporting 1 object(s)]
*** INFO computation : running external process [/home/jussi/tred/ahmedbody/manual_results/baseline/computation/input/Allrun in design baseline]
*** INFO LocalResourceManager : External process start failure. [Executable /home/jussi/tred/ahmedbody/manual_results/baseline/computation/input/Allrun could not be resolved to a valid file.]
*** INFO FGenIntReader : Could not open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation//postProcessing/forces/0/forceCoeffs.dat for reading [parsing process aborted]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/Ux_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/Uy_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/Uz_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/case.foam]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/contGlobal_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/contLocal_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/k_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/omega_0]
*** INFO FResultsGenInt : File read error [Failed to open file /home/jussi/tred/ahmedbody/manual_results/baseline/computation/logs/p_0]
How to get started to solve what is going wrong?
Hey Jussi,
Sorry for the late reply.
I assume you have read the project documentation and done this:
In order to initialize OpenFOAM, source your OpenFOAM dot-file before starting the CAESES/FFW from
the terminal or modify the loaction of the dot-file in the prepared stringparameter or the Allrun Script itself.
To start the computation go to SoftwareConnector and start the application with a right click on the central element and then "Run".
You can also take a look in the Taskmonitor (you can find it on the right side of the CAESES window)
It contains the console output of the allrun script and openfoam.
You can also find two tutorials with an OpenFOAM integration.
Documentation > Tutorials > Integration
Does this help?
I am having the same problem (I think). I have spent a week trying to solve this by myself but I really can't see the problem.
Below is th copied text from the stdouterroroutput.redirect file:
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 5: .: Can't open /home/alasdair/OpenFOAM/OpenFOAM-2.3.1/bin/tools/.RunFunctions
ANy help would be appreciated.
Regards.
Alasdair.
Hi Alasdair,
the first lines of your Allrun script should look like:
#!/bin/sh
cd ${0%/*} || exit 1 # run from this directory
chmod +x Allrun.pre
. /home/carsten/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
# Source tutorial run functions
I just realized that the source command does not work, instead you should use the dot :
use
instead of
source /home/carsten/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
I hope this works for you
Hi Carsten,
thaks for replying. I have tried a few variations of the allrun script, currently it looks like this:
#!/bin/sh
. /home/OpenFOAM/OpenFOAM-2.3.1/bin/tools/RunFunctions
chmod +x Allrun.pre
wmUNSET
. /home/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc
touch case.foam
./Allrun.pre
runApplication decomposePar
runParallel `getApplication` 4
runApplication reconstructPar
This has changed the error message in stdouterroroutput.redirect to:
[Captured output from application /home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun]
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 5: .: Can't open /home/OpenFOAM/OpenFOAM-2.3.1/bin/tools/RunFunctions
I am a bit stuck.
Alasdair.
Hi Carsten, I have done that, and that changes the error file to:
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 4: /home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: wmUNSET: not found
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 5: .: Can't open /home/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc
Alasdair.
Hi Carsten,
I tried changing the file path as suggested and removin wmUNSET, error file reads:
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 1: /home/alasdair/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc: /data/app/OpenFOAM/OpenFOAM-2.3.1/bin/foamEtcFile: not found
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 1: /home/alasdair/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc: /data/app/OpenFOAM/OpenFOAM-2.3.1/bin/foamCleanPath: not found
/home/alasdair/OpenFOAM/AH81_OpenFOAM_Propeller/manual_results/baseline/Runner//Allrun: 141: .: Can't open /data/app/OpenFOAM/OpenFOAM-2.3.1/etc/config/settings.sh
here ae the contents of the OpnFOAM2.3.1 folder (from typing ls in terminal from within etc directory)
alasdair@alasdair-HP-xw4600-Workstation:~/OpenFOAM/OpenFOAM-2.3.1/etc$ ls
bashrc   caseDicts   codeTemplates  controlDict  thermoData
bashrc~  cellModels  config         cshrc
Alasdair.
Hi Carsten,
yes, plase see copy and paste from teminal from within tools directory (afte typing ls):
alasdair@alasdair-HP-xw4600-Workstation:~/OpenFOAM/OpenFOAM-2.3.1/bin/tools$ ls
CleanFunctions         foamListBinDirs            pre-commit-hook
doxyFilter             foamListSourceFiles        pre-receive-hook
doxyFilter.awk         foamListThirdPartyBinDirs  README
doxyFilter-ignore.awk  foamLog.db                 replaceAllShellSun
doxyFilter.sed         gtagsrc                    RunFunctions
doxyFilter-table.awk   inlineReplace              scanpackages
doxyFilter-top.awk     MakefileDirs
foamConfigurePaths     org-batch
Alasdair.
Hi Carsten, I have already done that as I saw the post when I forst started trying to get this to work - please see below copy paste from my CAESES -FFW file:
foamDotFile=$FOAM_INST_DIR/OpenFOAM-2.3.1/etc/bashrc
Alasdair.
