CJ Coll
Sobol Optimisation Hull Exporting
I have ran a Sobol Optimisation for a ship hull and want to have a trimesh surface exported for each hull variant.
So far I have been saving them all as individual CAESES projects and then exporting the trimesh manually. Is there an easier way to do this?
Within CAESES, the input and/or output geometry can be automatically exported to the corresponding folder in an optimization setup.
You can find a demonstration of the integration of STarccm+ with CAESES in our software by accessing the Help workspace and searching for "star-ccm".
Best Regards,
Andreas
Input Geometry
Thank you, so if I run a basis simulation in the connection part and get my required results, then I go to the optimisation and use Sobol analysis. How do I then run all these hull variants through StarCCM.
Or is this done when I run the sobol analysis?
If I have run the initial simulation through CAESES and now I want to run it through the Sobol analysis but I only want to analyse, say, designs 0,8,11,15,19. How can I specify this before CAESES runs all 20 variants through StarCCM, which would take far too long?
