Jake Smith 0 Report post Posted September 20, 2023 Hi,friendship guys! I use the MRF method to optimize the propeller design on Workbench. But there will be problems when sharing topology in Fluent Meshing. I would like to ask if it is possible to complete the shared topology operation in CAESES. Looking forward to your reply, thank you! Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted September 21, 2023 Hi Jake, Inside Workbench, if your geometry module is DesignModeler; open it and define the geometries as shared topology as usual. However if your geometry module is SpaceClaim; within the ACT App Properties Menu, you should find an entry only dedicated for SpaceClaim where you can assign the topology type. I will be back in the office end of September. We can have a web-meeting if you have any questions once I am back. Cheers Ceyhan Share this post Link to post Share on other sites
Jake Smith 0 Report post Posted September 22, 2023 Hi Ceyhan, I have solved the problem of shared topology. But the problem that the geometry cannot be updated automatically still exists.The complete project can be found in the file sent to your email address. By installing the latest ACT components in WORKBENCH 2023R1. Then call the 4.4.2 version of CAESES and you should be able to reproduce the issue. thank you for your reply! Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted September 27, 2023 Jake, Ceyhan is not in the office these days. Will take a little until he responds 😕 Best Regards Claus Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted October 4, 2023 Hi Jake, I am finally back in the office. May I ask you why you are using an old version of Caeses? Did you try Caeses v5? Cheers Ceyhan Share this post Link to post Share on other sites
Jake Smith 0 Report post Posted October 8, 2023 Hi Ceyhan, The reason I'm using an older version of CAESES is because the license for the new version is a trial license. When using the ACT function, remote verification may be required. Verification may fail due to network issues. Therefore, I cannot import geometry from the new version of CAESES on WORKBENCH. Next, I'll apply for an offline license and try again. Thank you very much for your reply! Share this post Link to post Share on other sites
