Yukai
Chamfer deformation parameterization setting
Hello!
If I want the chamfer of the model to automatically deform at 0~45 degrees, how should I set it?
The current model is an STL file, and I use MeshMorph and freeformdeformation to set it.
I created a Rectangular Box to set the deformation range, but I don't know how to set the reference point of the deformation.
The red line in the appendix is the oblique angle.
Thanks for your help!!!
Best Regards
YuKai
Hi Yukai,
The surface you would like to modify is an axi-symmetrical surface.
It will be way easier; to get rid of that surface, create a profile controlled by parameters and then rotate it around the axis.
Ceyhan
