Nuttarat Vichanphruek 0 Report post Posted May 20, 2022 Hi, I have a project to run the simulation on cluster. I set up everything correctly from STAR CCM+ and follow your tutorial perfectly, so I can run the simulation on CAESES via software connection tool on the normal computer. By the way, when I try to run this again on cluster, it does not work. I do not know what is problem. I would appreciate a lot if you anyone can suggest. This is my argument for executing: "starccm+ -batch -podkey I*******w -licpath 1999@flex.cd-adapco.com setup.java intake_optimization_0.762.sim" intake_optimization_0.762.sim is my simulation file name. After running, the file viewer shows this: Error: /software/sse/manual/star-ccm+/2021.3/16.06.008-R8/STAR-CCM+16.06.008-R8/star/bin/starccm+: Unknown option: intake_optimization_0.762.sim. Share this post Link to post Share on other sites
Ceyhan Erdem 14 Report post Posted May 23, 2022 Hi Nuttarat, Can you please let me know your availability so that we can arrange a web-meeting and I can check your setup. You can write to erdem@friendship-systems.com Please take into consideration that we are locate at Central European Time Zone. Cheers Ceyhan Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted May 24, 2022 Hi, I think you need to provide the full path to the sim file. You can do this by using with the command getInputDir()/intake_optimization_0.762.sim. best Regards Carsten Share this post Link to post Share on other sites
