Mr. Stephane Sanchi 2 Report post Posted July 3, 2013 SOLVED: Please check the last page. Hi Konrad, I just installed release 3.0.9. I still use KDE.But the problem remains. 1. Launching normally the software (./CAESES-FFW.sh) it crashes after 1-2 object manipulation: /home/stephane/Softs/CAESES-FFW/CAESES-FFW_3.0.9_Linux.x86_64/CAESES-FFW.sh: line 75: 5068 Segmentation fault ${HERE}/bin/Linux.x86_64/CAESES-FFW $ARGS "$@" 2. If I doexport LD_LIBRARY_PATH=/home/stephane/Softs/CAESES-FFW/CAESES-FFW_3.0.9_Linux.x86_64/lib/Linux.x86_64/gdb /home/stephane/Softs/CAESES-FFW/CAESES-FFW_3.0.9_Linux.x86_64/bin/Linux.x86_64/CAESES-FFW > run Then the software remains frozen after the creation of the NACA 4DS-curve object !!! Stéphane. Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted July 5, 2013 Hey Stéphane, I can't reproduce the behavior you mentioned. On my linux maschine it works fine. Could you please try the following steps and anwser the questions: Which grafic card do you have? Is a proprietary 3D GPU driver installed?You can check this with the terminal: type in the following command: glxinfo | grep -i render The message should be something like:direct rendering: YesOpenGl renderer string: your grafic card.....is rendering states Yes -> you have installed a proprietary 3D GPU driver. 3. you can start CAESES-FFW.sh in a none gtk modus. Open CAESES-FFW.sh with an editor (e.g. gedit)change line 38 from #ARGS='$ARGS -gtk' to ARGS='$ARGS -no-gtk'close and save the fileStart CAESES-FFW.sh again 4. Last but not least use gnome instead of KDE if none of the previous steps are working Hope this helps and tell us if it solved your problems Best Regards Karsten Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 8, 2013 Hi Karsten, hereafter some details about my graphic cards: stephane@mylaptop:~> glxinfo | grep -i renderdirect rendering: YesOpenGL renderer string: Mesa DRI Intel® Ivybridge Mobile GL_NV_conditional_render, GL_AMD_draw_buffers_blend,stephane@mylaptop:~> /sbin/lspci | grep VGA00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)01:00.0 VGA compatible controller: NVIDIA Corporation GK107 [Quadro K2000M] (rev a1) The software still crashes with the following modification:change line 38 from #ARGS='$ARGS -gtk' to ARGS='$ARGS -no-gtk' I haven't tried the gnome solution. When I use the zoom windows it crashes 99%. What do you think if I try to install the software under Windows 7 ? Regards, Stephane. Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted July 8, 2013 Hey Stephane, thanks for trying the instructions.For some reason your Laptop uses the internal graphic card (OpenGL renderer string: Mesa DRI Intel® Ivybridge Mobile).Can you switch or force your laptop to use the nvidia graphic card? If you have installed windows 7 allready then install CAESES-FFW. And make sure the nvidia graphic card is active. Hope one solution will work. :-) Regards, Karsten Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 9, 2013 Hi Karsten, under Windows7 CAESES-FFW works fine with both graphic cards. This evening I will do a complete tutorial. But under opensuse it still crashes even if I force to use the nvidia graphic card (discrete graphics - BIOS). When I lauch CAESES-FFW I get this on the shell. Could it be the problem ?Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)CAESES-FFW 3.0.9 I want to understand where is the problem because I want to use CAESES-FFW with openFOAM under opensuse.Regards,Stephane. Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 10, 2013 Hi, I have installed the nvidia K2000M proprietary driver. stephane@mylaptop:~> glxinfo | grep -i renderdirect rendering: YesOpenGL renderer string: Quadro K2000M/PCIe/SSE2 GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image, GL_NV_parameter_buffer_object2, GL_NV_path_rendering, GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop, /sbin/lspci | grep VGA01:00.0 VGA compatible controller: NVIDIA Corporation GK107 [Quadro K2000M] (rev a1) It still crashes. /home/stephane/Softs/CAESES-FFW/CAESES-FFW_3.0.9_Linux.x86_64/CAESES-FFW.sh: line 75: 3966 Segmentation fault ${HERE}/bin/Linux.x86_64/CAESES-FFW $ARGS "$@" I need help to solve this problem ! Stephane. Share this post Link to post Share on other sites
Mr. Claus Abt 10 Report post Posted July 11, 2013 HI Stephane, Our Linux experts have not been in since your post. We'll help asap. CheersClaus Share this post Link to post Share on other sites
Mr. Adjei Richard 0 Report post Posted July 12, 2013 Hi,Im Richard. Im having problems running my FFW setup. first i install the software, then try to run via shortcut on desktop. usually i receive the message " error: request time out" and " no connection to license server..........". when i changed the version from 3.06 to 3.08 , it starts running then stops without any message. Ive checked my time synchronisation, and switched off my firewall but nothing seems to work. my system runs on win 7and its 64 bit. N.B: i cannot upload pictures. whenever i try , i receive this message" Error The server returned an error during upload" Thanks Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted July 12, 2013 When I lauch CAESES-FFW I get this on the shell. Could it be the problem ?Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)CAESES-FFW 3.0.9 Hi, yes, actually this can be the problem. Please make sure to install a HAL demon (see http://en.wikipedia.org/wiki/HAL_%28software%29). If I am not mistaken udev should be fine, too, but we have to wait for our Linux expert as Claus said. when i changed the version from 3.06 to 3.08 , it starts running then stops without any message. Please try again with version 3.0.9.Could you maybe add some more details about "it starts running"? What's the last thing you see?Also, please post the startup logfile if the problem persists (see the following post for details on how to locate it: http://www.friendship-systems.com/forum/index.php?/topic/28-how-do-i-handle-error-messages-when-starting-the-framework-or-caeses/ ). Share this post Link to post Share on other sites
Mr. Adjei Richard 0 Report post Posted July 12, 2013 hi, Ive tried the versions 3.05 to 3.09 but no change. i mean after installation and it begins to open the FFW interface, it then suddenly vanishes from the screen without any message. i dont think the problem is from the setup but possibly connection to the license server. Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted July 12, 2013 Could you please post the startup logfile. See my last post for information how to find it. Share this post Link to post Share on other sites
Mr. Adjei Richard 0 Report post Posted July 12, 2013 hi i have, i used the issue tracker. have you seen it? Share this post Link to post Share on other sites
Mr. Claus Abt 10 Report post Posted July 12, 2013 Hi Adjei, What kind of anti-virus software do you use? In the past we have experienced problems with some free softwares that simply killed CAESES. If so, maybe you can switch it off for a moment. Share this post Link to post Share on other sites
Mr. Adjei Richard 0 Report post Posted July 12, 2013 hi,i use 360. my old machine used the same antivirus but i had no problems. Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 17, 2013 Hi, I have installed HAL. But the problem and the message remain. Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0)Couldn't find HAL. Is HAL running? (x.1.0) And it is worse because it takes a few minutes before the GUI appears. So I have decided to uninstall it. Stephane. Share this post Link to post Share on other sites
Mr. Konrad Lorentz 2 Report post Posted July 19, 2013 Hi Richard, please do not cross-post in this forum. Your issue was resolved via IssueTracker. Hi Stephane. You don't need HAL! Don't invest time in it! Your OS is using UDISKS2, which we support too, to get the same information we need. Please post the startuplog! .friendship/etc/logs/startuplog.html please install GDB (zypper install gdb) start the CAESES-FFW as follows: cd /tmp/ cd CAESES-FFW_3.0.9_Linux.x86_64 export LD_LIBRARY_PATH=lib/Linux.x86_64/ echo run | gdb bin/Linux.x86_64/CAESES-FFW if you get the segfault: enter "bt" and press ENTER. Please send me the output. RegardsKonrad Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 19, 2013 Hi Konrad, which kind of file can I attach ? I can't attached *.txt file ! Stephane. Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted July 19, 2013 Hi Stephane, zip the files, you can attach zips. Best regards,Arne Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 19, 2013 Hi Konrad, find attached 2 files:startuplog.htmlinfo.txt Regards,Stephane PS : thanks Arnekonrad.tar Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted July 19, 2013 Hi Stephane, Please enter "bt" before you do the quit out of gdb. bt is a gdb command. I.e. instead of this: updating geometry - ok[New Thread 0x7fff772ba700 (LWP 4056)] Program received signal SIGSEGV, Segmentation fault.0x00007fffe733d13a in QWidgetPrivate::reparentFocusWidgets(QWidget*) () from lib/Linux.x86_64/libQtGui.so.4(gdb) quitA debugging session is active. Inferior 1 [process 4038] will be killed.---Type <return> to continue, or q <return> to quit---Quit anyway? (y or n) [answered Y; input not from terminal]stephane@mylaptop:~/Softs/CAESES-FFW/CAESES-FFW_3.0.9_Linux.x86_64> btIf 'bt' is not a typo you can use command-not-found to lookup the package that contains it, like this: cnf bt it should be: updating geometry - ok[New Thread 0x7fff772ba700 (LWP 4056)] Program received signal SIGSEGV, Segmentation fault.0x00007fffe733d13a in QWidgetPrivate::reparentFocusWidgets(QWidget*) () from lib/Linux.x86_64/libQtGui.so.4(gdb) bt Then send the output of the "bt" command. Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 19, 2013 Hi, it quits by itself !!! I can't enter bt !!! Program received signal SIGSEGV, Segmentation fault.0x00007fffe733d13a in QWidgetPrivate::reparentFocusWidgets(QWidget*) () from lib/Linux.x86_64/libQtGui.so.4(gdb) quit Stephane. Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted July 19, 2013 Ah, ok, sorry. Please try to leave out the "echo run |" part of the command line. So just do gdb bin/Linux.x86_64/CAESES-FFW It will then start to a prompt: GNU gdb (GDB) SUSE (7.5.1-2.1.1)Copyright © 2012 Free Software Foundation, Inc.License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>This is free software: you are free to change and redistribute it.There is NO WARRANTY, to the extent permitted by law. Type "show copying"and "show warranty" for details.This GDB was configured as "x86_64-suse-linux".For bug reporting instructions, please see:<http://www.gnu.org/software/gdb/bugs/>...Reading symbols from /home/stephane/Softs/CAESES-FFW/CAESES-FFW_3.0.9_Linux.x86_64/bin/Linux.x86_64/CAESES-FFW...done.(gdb) Enter "run" (without quotes). I hope that way, gdb will give you the chance to issue the "bt" command after the segfault occured. Arne Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted July 19, 2013 Hi, when I run: gdb bin/Linux.x86_64/CAESES-FFW and then: run then FFW frezzes and I can't write bt. I often have my problem when I use the Ctrl key and left button (windows from bottom right to top left) to select entities (curves near the open trailind edges of a NACA-4DS curve) Stephane. Share this post Link to post Share on other sites
Mr. Stephane Sanchi 2 Report post Posted August 27, 2013 Any new idea to solve my problem ?Regards,Stéphane. Share this post Link to post Share on other sites
Mr. Konrad Lorentz 2 Report post Posted August 28, 2013 Hi Stephane, as Arne instruct you: please enter the bt before the quit! Share this post Link to post Share on other sites
