Ms. Eloise Croonenborghs 0 Report post Posted November 7, 2019 Hello,I need to measure the projected frontal area of my vessel, split into below/above waterline. Can someone help me find the proper commands?My hull is of trimesh type.Thanks!Regards,Eloïse Share this post Link to post Share on other sites
Mr. Claus Abt 11 Report post Posted November 8, 2019 Hi Eloïse,Please feel free to use the helpdesk, that will probably result in much quicker response. Do you have one x-position where you could cut your trimesh by a sectionGroup (only one section)? Then you can ask the section for its area, trim at the waterline etc ....CheersClaus Share this post Link to post Share on other sites
Mr. Daehwan Park 1 Report post Posted November 12, 2019 Hi Eloise The procedure to get a section area is like below : 1. Create a SectionGroup at one x position from trimesh, surfaces or brep.2. Convert the SectionGroup to OffsetGroup.3. Extract an offset4. Create a BSplinecurve from the offset5. Cut the curve at draft (using ImageCurve manipulation.)6. Get the areas from lower curve and upper curve. All steps are introduced in the FDB you could download from the link : https://www.friendship-systems.de/fcloud6/public.php?service=files&t=d919b7d1cdf4721c05027b3e522dd746 As Claus said, I also recommend to use HelpDesk for any questions. CheersDaehwan Share this post Link to post Share on other sites
