Mr. Karl Hohenberg 0 Report post Posted August 29, 2019 Hi there, In the attached model, if SURFACE is set as the surface for the intersection curve (intersection with principal plane) I get an error and CAESES crashes. This also happens if the same surface is intersected with another surface, not just in principal plane mode. Is there a particular reason for this, or is it just a bug? Many thanks,KarlTURBINE.fdbc Share this post Link to post Share on other sites
Ceyhan Erdem 15 Report post Posted August 30, 2019 Hi Karl, Thank you for reporting the crash. I was able to recreate the problem.Now there is a ticket created for the developers to figure out the root cause of the crash. CheersCeyhan Share this post Link to post Share on other sites
Ms. elysse perry 1 Report post Posted December 27, 2019 I am trying to create a duct with dual outlets and diffuser capabilities. I have followed the swept duct tutorial and created the general parametric geometry I am looking for. The problem I am having is that https://tradevenue.se/ I want the two mirror image parts to intersect as an open channel. I have tried solid from intersection, boolean operations, but to no success. Any help would be greatly appreciated. Share this post Link to post Share on other sites
Ceyhan Erdem 15 Report post Posted January 2, 2020 Hi Elysse, Is it possible for you to share your project file, so that I can give a look? CheersCeyhan Share this post Link to post Share on other sites
