Mr. Kim Moo Sung
optimization with batch mode
Hi Moo Sung,
to start a design engine in batch mode you can use the command yourDesignEngine.run(true)
using .run(true) takes into account the existing result pool (e.g. links the designs already evaluated in different runs) while .run(false) will not take into account any previous runs.
This way you should be able to run your design engines one after the other.
