Mr. Bodo Hasubek 3 Report post Posted August 28, 2018 UPDATE: CAESES 4.4.1 comes with the lastest libpng12.so.0.59.0 and all the symbolic links set correctly (so forget about steps 1. - 4- below). However, removing libz (step 5) is still required under (K)Ubuntu 18.04. ORIGINAL POST: CASES 4.3.1 doesn't run on (K)Ubuntu 18.04 out of the box because it requires libpng12 that isn't readily available for 18.04. Here my work around: Get libpng12 (64-Bit) from https://packages.ubuntu.com/xenial/amd64/libpng12-0/download (This is the latest version for (K)Ubuntu 16(!).04) Extract libpng12.so.0.54.0 from the downloaded .deb package (I used ark and just looked through the file until I found it in /lib/x86_64-linux-gnu) Copy libpng12.so.0.54.0 to the lib-directory of your CAESES-Installation (usually something like ~/CAESES_4.3.1_Linux.x86_64/lib/Linux.x86_64) Set the symbolic link ln -s libpng12.so.0.54.0 libpng12.so.0 (in the lib directory) REMOVE libz.so libz.so.1 libz.so.1.2.5 from yor CAESES-lib-directory (They are too old and apparently the newer version comes with 18.04) Make sure your proprietary graphics driver is installed. Worked like a charm for me. Hope it helps.Regards,Bodo 1 Share this post Link to post Share on other sites
Jörg 29 Report post Posted August 29, 2018 Thanks Bodo! :) Share this post Link to post Share on other sites
Mr. Bram1 Kerkhofs1 0 Report post Posted October 19, 2018 Hi Bodo Thanks, your solution did help me the libpng12-errorI also needed to install the canberra-gtk-module, by simply doing sudo apt install canberra-gtk-module Afterwards I had a problem with the licensing: it returned the error: The license file contains hardware keys not corresponding to this workstation. Please send us an email with the failed identifiers!So i tried to start caeses by "./CAESES -resetauth"But it didn't work out. So Joerg, here comes my e-mail :). RegardsBram Share this post Link to post Share on other sites
Mr. Sebastian Uharek 1 Report post Posted October 19, 2018 Please start CAESES with the following command line flag: CAESES -serialgui and send us the license request file.We will have to change the hardwaremap of your license file.Best regards,Sebastian Share this post Link to post Share on other sites
Mr. Hussien mohamed hassan 0 Report post Posted January 10, 2019 hello,there are any option for shipflow wizard Share this post Link to post Share on other sites
