Mr. hamid reza 1 Report post Posted June 20, 2017 Hello all,Is there any way to pass the output of the feature as input of some other features, without repetitive run of the referred one? For example:I am trying to run my algorithm as shown in the attached figure. At first the FeatureNo1 ran to get some inputs and calculate some values and objects. Then these value and objects have to pass to FeaturesNo2, FeaturesNo3, FeaturesNo4. For completing my process, I need to run all the Ffeaures. I don’t want to combine all the features in one, because it will be so unclassified and difficult for tracing and development. So, I used the nested feature option and call the output of featureNO1 inside of each mentioned features (No2 to No4), then the features would be run in following order. fp_ FeaturesNo2 no2()no2.run()Fp_FeaturesNo3 no3()no3.run()Fp_FeaturesNo4 no4()no4.run() Therefore, the FeatureNo1 run three times, because each feature calls the output of NO1 separately. So, is there any idea to escape of this repetition? Best RegardsHamidreza Share this post Link to post Share on other sites
Stefan Wunderlich 6 Report post Posted June 21, 2017 Hi Hamidreza, You could create an instance of FeatureNo1 in your project and pass it as argument to 2, 3 and 4. Once it is up to date it would not run again.Simply create an argument of type FFeature::FeatureNo1 in 2, 3 and 4. Best regards,Stefan Share this post Link to post Share on other sites
Mr. hamid reza 1 Report post Posted June 21, 2017 Hi Stefan Thanks, it works now BRHamidreza Share this post Link to post Share on other sites
