Mr. Kevin Noob 0 Report post Posted January 11, 2017 Hi all, noob here. I have a design question I was hoping to get some assistance with. I wanted to create a simple spiral, just a line rotating around an axis z. However, I want to be able to change the rate that it is rotating about z. So it would be a spiral that would get tighter as it went, or whatever you wanted hopefully tied to a function. A parabola would make a spiral that starts with slow rotation, gets tighter in the middle, and loosens back up. I believe this should be pretty simple but I haven't figured it out. Any assistance is greatly appreciated. (the more detail the better...noob here)Thanks Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted January 11, 2017 Hi Kevin,you can use the generic curve and implement the definition of a helix. For the radius, you can define a function, for example a bsplinecurve with 3point. This function can be defined in xy plane, where the y coordinate defines the radius. Attached is an example for this. best regards Carstenhelix.fdb Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted January 11, 2017 Kevin,For a spiral surface you can also find a thread here.CheersClaus Share this post Link to post Share on other sites
