Mr. Lalym Yuriy 0 Report post Posted March 14, 2016 When a certain combination of input parameters of the curve (GetFlareAtDWL::c1) behaves differently. Failure is seen on the curve (flare_at_dwl) representing the operation result and the graphs vertices of FSpline curve. FSpline.fdbc Share this post Link to post Share on other sites
Mr. Lalym Yuriy 0 Report post Posted March 14, 2016 I'll build myself a very smooth curve angles and input data will generate the surface. If you roll the surface there is visible emissions and without curvaturePSInterpolated points: The issue is not quantity, but you need to get in trouble spots FSpline1.fdbc Share this post Link to post Share on other sites
Jörg 29 Report post Posted March 15, 2016 Hi, I have to admit that I do not fully understand your issue. And, in your project file it is not clear what to change to see the behavior that can be observed in your screenshots. One thing that I can say is that we recommend skinning as the NURBS generation process for meta surfaces. For such a surface, a good number (of interpolation points in surface direction) is in the range 20-50. 205 etc is far too much. But maybe you have used this number to better provoke and investigate this behavior. CheersJoerg Share this post Link to post Share on other sites
