Guest Mr. Harry Gatley
Chemical Equilibria
I need help modeling reactors in petroleum refining
Guest Mr. Harry Gatley__0001
Physical and in many shapes and sizes.  These reactors have fixed beds of catalyst and also appear as coiled tubes in direct fired heaters without catalysts.  The catalyst manufacturer gives us a space velocity they guess will fit the reactants and we then build the reactor.  I want to be able to use a mesh and generate the fluid flows including the chemical equilibria at each node as they change with heat and mass transfer, pressure and temperature.
I use AutoCAD to develop a mesh.
