Mr. Md Shahriar Nizam 0 Report post Posted February 5, 2015 Hello Guys, I need to make a nurb/bspline surface from a .pan file later on i need to make sections from the file.Thanks in advance.I am trying to attach a .pan file but could not do it so can anybody give me an example for this problem also.Thanks,Shahriar Share this post Link to post Share on other sites
Mr. Mattia Brenner 6 Report post Posted February 5, 2015 Hi, to be honest, I am not really familiar with the .pan format. I assume it is a panel format. If so, is it structured or unstructured? Is it an ASCII or binary file? In the case of a structured panel mesh in ASCII format, things shouldn't be too difficult. You can import the lattice of nodes with a feature (see this post http://www.friendship-systems.com/forum/index.php?/topic/93-feature-for-import-or-export-of-point-data-to-ffwcaeses/) and then e.g. interpolate them with curves row by row and loft these curves with a surface. In case of an unstructured mesh or a binary file things are more complicated... Cheers,Mattia Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted February 5, 2015 Hey Shahriar, Maybe you can you the feature definition I wrote for you a while ago. Or you can start with that one and make it fit the .pan file structure. Here is another example of a custom import feature. If you need further input do not hesitate to ask. :-)(An example file and more information about the .pan file will help in that case.) Cheers, Karsten Share this post Link to post Share on other sites
