Hi all,
I'm looking at feature programming samples. In the tutorial 'Loops' the debugging process shows some errors, so I replaced igesImport with igesDeprecatedImport:
FFile f(file.getFileName())
if (!f.exists())
  echo("Invalid input file, file does not exist.")
  break()
endif
igesDeprecatedImport importer()
importer.import(file.getFileName())
fobjectlist imported(importer.getLastImportedObjects())
unsigned curveCount(0)
double maxLength(-1)
unsigned index(0)
while(index < imported.getCount())
  FCurve c(imported.at(index).castTo(FCurve))
  if(!(!c))
    curveCount += 1
    maxLength = max(maxLength, c.getLength())
  endif
  index += 1
endwhile
echo("Analysis result for file " + file.getFileName() + ":")
echo("Number of curves: " + curveCount)
echo("The longest curve is " + maxLength + " units long")
I have no more errors, but the feature doesn't work as expected. The console output (the IGES file is the CAESES sample hull geometry containervessel.iges):
*** INFO IGES Import : entity type warning [detected type 314 is unsupported]
*** INFO IGES Import : entity type warning [detected type 406 is unsupported]
*** INFO IGES Import : entity type warning [detected type 308 is unsupported]
*** INFO IGES Import : entity type warning [detected type 408 is unsupported]
Analysis result for file C:/Program Files (x86)/FRIENDSHIP-SYSTEMS/CAESES-FFW/tutorials/06_hull_design/containervessel.iges:
Number of curves: 0
The longest curve is -1 units long
1. The File / Import menu includes IGES and IGES (Subset, Deprecated) importing tools. Does any command replace igesImport in feature programming? Does exist only igesDeprecatedImport?
2. What's wrong with IGES entity types in the code above?
I can't find any documentation about IGES importing commands. Thanks for your help.
Hi Maurizio,
Thanks for this information. We recently changed the file "containervessel.iges", since it had some issues. And, our IGES import has also changed within the last weeks and months. So it is an unlucky combination ;-) Our old i.e. deprecated IGES import cannot cope with the given IGES entities which is the reason for your output.
We will take a look at it (and also at this loop example) and get back to you as soon as this problem is solved.
Best regards
Hi Joerg,
if you are going to review the tutorial, I have other feedbacks ;)
1. the sample hull geometry basicosv.igs doesn't show IGES types problems, but the tutorial feature doesn't work properly and no curves are listed and measured (sorry, if no curves are included in the IGES model :))
2. I think that the feature code in the 'Loops' tutorial (p. 3) includes another error (too many slashes). I replaced
resolveEnv("$TUTORIALSDIR")+"/06_hull_design/containervessel.iges"
with
resolveEnv("$TUTORIALSDIR")+"06_hull_design/containervessel.iges"
Maurizio
  • Downvote 1
