Mr. Toni Klemm 0 Report post Posted November 5, 2014 Hello everybody, is there an easy way to generate a FSurfaceCurve from a curve which is directly located on an surface?I think on curve typ meridionalcamber which is developed along a Surface of Revolution (meridian contour)?This would be fine to generate the hub or shroud surface for a rotational periodic blade passage. Toni Share this post Link to post Share on other sites
Jörg 29 Report post Posted November 6, 2014 Hi Toni, There is no functionality in the menu for this so far. We have it in our library i.e under the hood, but it is not available to the user yet. Anyway, here is a workaround: I attached a simple example where the surface curve is generated by means of an intersection curve. See also the screenshot for getting a quick idea. This should do the job if the intersection on the hub surface is unique. I set the type provider of the feature definition to this intersection curve, so that you can readily use this feature "as a curve". For subsurface modeling, the domain curve "dc" is also given, see the second screenshot below. Does this help? CheersJoergmeridionalcamber_surfacecurve.fdb Share this post Link to post Share on other sites
Mr. Toni Klemm 0 Report post Posted November 6, 2014 Hello Jörg, thanks for your reply. I took your feature as idea for a feature which meet my requirements.Maybe you have some comments to it? Toni Share this post Link to post Share on other sites
Mr. Toni Klemm 0 Report post Posted November 6, 2014 ... file attached.meridionalcamber_surfacecurve.fdb Share this post Link to post Share on other sites
