Matthias Maasch 20 Report post Posted September 26, 2014 Hi folks please find attached a Feature Definition for a "Bulbous Bow Shape Analysis" and a Feature Definition which can be used in a CurveEngine for creating a MetaSurface. shapeAnalysis_Bulbous_Bow.fdf bulbous_bow_section.fdf [edited 05.10.14 - tangent analysis included] In order to replace a Bulbous-Bow-IGES-Import by a fully parametric MetaSurface you can use this Feature by execute the following steps: Create a Surface Group including all the IGES-surfacesCreate a new Feature Definition and reload the Analysis-Feature, apply and create the Feature by right click on the Feature Definition>Create FeaturePass the Surface Group to the Analysis-Feature and enter (if necessary) start- and end-position in x-direction of the bulbous bowAdditionally give a number of offsets (30-50 should be a good choice)Run the Feature This will create function curves which can be used to create a MetaSurface. The next steps should be: Re-model the function curves by e.g. FSplineCurvesCreate parameters for some values of the new curves, like start/end position, start/end tangent or area Create a CurveEngineCreate a new Feature Definition, reload the Section-Feature and applySelect the Bulbous-Bow-Section-Feature and pass the new function curves to the EngineAdditionally you can set start- end end-tangent valuesCreate a MetaSurface, select the Curve Engine and set the base positions according to the start- and end-position in x-directionNow you will have a single Metasurface, which is parametric and ready for a design study. Cheers Matthias 1 Share this post Link to post Share on other sites
Mr. MAYTHU ZAW 0 Report post Posted January 3, 2018 Hi, I am doing this as you said above ..But I don't know how to remodel function curve to F-spline.Could you explain this step for me? Thank you Share this post Link to post Share on other sites
