Mr. Alex Alex
Parametric model from stl file of monohull
I'm a newbie in the FFW and I need help with the criation of a simple parametric model of a simple flatwater monohull. I've read some tuturials but still do not have a proper model. I have both the stl file and a set of cloud points (in *.asc format) to start from, but need some help!
Can anyone help me on this issue, please!
Alexandre
files.zip
Hi Alexandre,
I imported your STL-file and it looks a bit strange. It seems like the hull might be compressed in x-direction. Any idea?
The best way to get started with a parametric hull model is to do the tutorial "Yacht Hull" (after some of the initial tutorials to get to know the basics of the software)
In comparison to this tutorial it is only a matter of defining a different section topology and different longitudinal curves for your hull, but the method is the same.
Mattia
