Britton Ward 0 Report post Posted May 30, 2014 Hi. I've written a small program to do some geometry modifications and have set it up as a local software connector. The executable call is as follows: "C:/Work/Programming Projects/FFDMorph/FFDMorph/Debug/FFDMorph.exe" "C:\Program Files (x86)\FRIENDSHIP-SYSTEMS\CAESES-FFW\my projects\SRFTest\SRFTest\manual_results\baseline\input\export.srf" "C:\Program Files (x86)\FRIENDSHIP-SYSTEMS\CAESES-FFW\my projects\SRFTest\SRFTest\manual_results\baseline\input\FFDMorph.in" the arguments to be passed to the program consist of the two file names with paths. Because my program is fortran it requires the two path strings to be surrounded by quotes as above. I can't seem to figure out how to combine the two filename strings within the framework into a single string that contains the quotes to close the first path and open the second with a space between. FSExport|f1:file.getFileName() + " " + FFDInputFile:file.getFileName() -> what syntax is needed to get the quotes to appear in here? "C:\Program Files (x86)\FRIENDSHIP-SYSTEMS\CAESES-FFW\my projects\SRFTest\SRFTest\manual_results\baseline\input\export.srf C:\Program Files (x86)\FRIENDSHIP-SYSTEMS\CAESES-FFW\my projects\SRFTest\SRFTest\manual_results\baseline\input\FFDMorph.in" or is there a way to have more than one argument for a software connector? Thanks Share this post Link to post Share on other sites
Mr. Arne Bergmann 27 Report post Posted May 30, 2014 Hi, what you need to do is "escape" those quotes using a backslash: "\"" + FSExport|f1:file.getFileName() + "\" \"" + FFDInputFile:file.getFileName() +"\"" This is not only necessary for fortran code, but everytime you need to pass an argument to a program that contains spaces (e.g. pathes with spaces). Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted June 2, 2014 By the way, I have noticed in a preview that the spaces where replaced by some character, I don't recall what it was, but they where actually executed correctly.Claus Share this post Link to post Share on other sites
Britton Ward 0 Report post Posted June 2, 2014 Claus/Arne, I implemented Arne's poposal and it seems to work fine! Share this post Link to post Share on other sites
