Praveen
TurboGrid export erroring out in Workbench
Hello, All!
I've been using the latest version of CAESES.
I designed an axial fan blade, and using the Surface method in the TurboGrid export feature, created a CAESES FSC file.
When reading in the FSC file into the CAESES TurboGrid engine in ANSYS Workbench, the ANSYS extension log gives out this error:
Please let me know if there is a workaround for resolving this issue.
This is the entire transcript of the Workbench Extension log :
Extensions Log File
12/3/2024 4:28:58 PM
Resetting id_tg_task2
Deleting id_tg_task2
CALLING onaftertaskreset_TG(task)
CALLING get_system_TG(task)
CALLING getProcessName_TG(task)
getProcessName
task.Name at getProcessName= id_tg_task2
Geom_comp_name at getProcessName= id_tg_task2
end of getProcessName_TG(task)
getProcessName
onaftertaskreset_TG id_tg_task2
end of onaftertaskreset_TG(task)
CALLING createWorkFlow(task)
getProcessName
getProcessName
counterTG = 0
counter = 1
finished creating workflow
end of createWorkFlow(task)
CALLING createParameterSet_TG(task)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|chord|chord1 : 47.4911)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|chord|chord2 : 65.3502)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|chord|chord3 : 77.6049)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|chord|chord4 : 81.0107)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|chord|chord5 : 83.8507)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|metal|metal1 : 32.607)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|metal|metal2 : 33.3391)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|metal|metal3 : 37.167)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|metal|metal4 : 38.4693)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|metal|metal5 : 32.6073)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|setting|setting1 : 20.4546)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|setting|setting2 : 23.7288)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|setting|setting3 : 21.2557)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|setting|setting4 : 25.5824)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|setting|setting5 : 27.5514)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|stagger|stagger1 : 20.6363)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|stagger|stagger2 : 35.4184)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|stagger|stagger3 : 40.3953)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|stagger|stagger4 : 39.9846)
DP SET: |V2Opti|BladedComponent1|Fan|Functions|stagger|stagger5 : 39.2039)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|01_hubContour|radius2Factor : 1)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|02_shroudContour|radius2Factor : 1)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|04_leadingEdge|posHub : 0.05)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|04_leadingEdge|posShroud : 0.05)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt1 : 0)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt2 : 0)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt3 : 0)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|04_leadingEdge|thetaShroud : -20)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|05_trailingEdge|dist1 : 6.83)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|05_trailingEdge|dist2 : 6.83)
DP SET: |V2Opti|BladedComponent1|MeridionalContours|05_trailingEdge|dist3 : 6.83)
DP SET: |V2Opti|NOB : 3)
CALLING create_parameter_object(task)
added chord1 47.4911
added chord2 65.3502
added chord3 77.6049
added chord4 81.0107
added chord5 83.8507
added metal1 32.607
added metal2 33.3391
added metal3 37.167
added metal4 38.4693
added metal5 32.6073
added setting1 20.4546
added setting2 23.7288
added setting3 21.2557
added setting4 25.5824
added setting5 27.5514
added stagger1 20.6363
added stagger2 35.4184
added stagger3 40.3953
added stagger4 39.9846
added stagger5 39.2039
added radius2Factor 1
added posHub 0.05
added posShroud 0.05
added thetaInt1 0
added thetaInt2 0
added thetaInt3 0
added thetaShroud -20
added dist1 6.83
added dist2 6.83
added dist3 6.83
added NOB 3
finished reading params
end of createParameterSet(task)
CALLING update_TG(task)
CALLING onbeforetaskupdate_TG(task)
getProcessName
onbeforetaskcreation id_tg_task2
end of onbeforetaskupdate_TG(task)
getProcessName
getProcessName
CALLING updateUnits_TG(task)
end of updateUnits_TG(task)
inputParams : inCAESES_chord1 47.4911
inputParams : inCAESES_chord2 65.3502
inputParams : inCAESES_chord3 77.6049
inputParams : inCAESES_chord4 81.0107
inputParams : inCAESES_chord5 83.8507
inputParams : inCAESES_metal1 32.607
inputParams : inCAESES_metal2 33.3391
inputParams : inCAESES_metal3 37.167
inputParams : inCAESES_metal4 38.4693
inputParams : inCAESES_metal5 32.6073
inputParams : inCAESES_setting1 20.4546
inputParams : inCAESES_setting2 23.7288
inputParams : inCAESES_setting3 21.2557
inputParams : inCAESES_setting4 25.5824
inputParams : inCAESES_setting5 27.5514
inputParams : inCAESES_stagger1 20.6363
inputParams : inCAESES_stagger2 35.4184
inputParams : inCAESES_stagger3 40.3953
inputParams : inCAESES_stagger4 39.9846
inputParams : inCAESES_stagger5 39.2039
inputParams : inCAESES_radius2Factor 1.0
inputParams : inCAESES_posHub 0.05
inputParams : inCAESES_posShroud 0.05
inputParams : inCAESES_thetaInt1 0.0
inputParams : inCAESES_thetaInt2 0.0
inputParams : inCAESES_thetaInt3 0.0
inputParams : inCAESES_thetaShroud -20.0
inputParams : inCAESES_dist1 6.83
inputParams : inCAESES_dist2 6.83
inputParams : inCAESES_dist3 6.83
inputParams : inCAESES_NOB 3.0
CALLING get_system(task)
CALLING getProcessName(task)
getProcessName id_tg_task2 getProcessName
end of getProcessName(task)
os_ver: Win64
fscName=V2-Opti
baseline name=baseline
proj_type=cdbc
loading plugin libraries ...
plugbase - ok
plugblade - ok
plugcom - ok
plugdakota - ok
plugfeature - ok
pluggenericintegration - ok
plugkspline - ok
plugmeta - ok
plugnax - ok
plugopt - ok
plugoptmo - ok
plugsshrm - ok
plugxffl - ok
shfctrl - ok
initializing types ...
plugins - ok
basic object types - ok
entity types - ok
initializing commands ...
console cmds - ok
initializing configuration ...
*** INFO REPORTSERVER : started [port: 12345]
*** INFO Open project : V2-Opti [3.736 secs cputime | 3.7353 secs in worldtime]
true
|V2Opti|NOB
*** INFO Exporting : V2-Opti/manual_results/baseline/input/export_Blade_1.tin
true
***Caeses Error***
Error when invoking function 'update_TG'.
Traceback (most recent call last):
File "C:\Users\gambhirp\AppData\Roaming\Ansys\v242\ACT\extensions\CAESES_Workbench_App_23_09_2024_v2\turbo.py", line 430, in update_TG
StandardError: Exception has been thrown by the target of an invocation.
UnboundLocalError: Local variable 'file_name' referenced before assignment.
Hi Praveen,
Can you please be sure that your fsc file is up to date and the project saved.
After this check, if you still face the same problem, can you please provide me your project file?
You can send the file to erdem@friendship-systems.com.
Ceyhan
All,
The workaround for this issue was:
- Have the blade surface be slight extended above the shroud curve, and slightly below the hub curve.
- Have the Suction and Pressure side curves extracted on the un-extended blade surface for sources
- Have leading edge and trailing edge curves extracted
      - Ideally, using trimmed blade surfaces by domain extents (U,V)
- Having these, you can define your TurboGrid export options, and would translate into ANSYS Workbench with no issues.
Hi All,
Following up on this topic,
I am encountering similar issue as @Praveen mentioned and the workaround doesn't seem to be working.
Extensions Log File
1/26/2026 12:45:39 PM
CALLING onbeforetaskupdate(task)
onbeforetaskupdate id_tg_task2
end of get_system(task)
end of onbeforetaskupdate(task)
getProcessName
getProcessName
getProcessName
getProcessName
getProcessName
counterTG = 0
counter = 1
CALLING sync_TG_parameters_from_lines
Added TG parameter 00_Functions|04_RatioDistSpanwise|02_RangeBased|ratioHub = 0.3
Added TG parameter 00_Functions|03_chordDistSpanwise|02_RangeBased|chordHub = 8
Added TG parameter 00_Functions|02_staggerDistSpanwise|02_RangeBased|staggerMid = 57.93
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posHub = 0.25
Added TG parameter 00_Functions|06_statorDist|01_CamberAngleDist|camber80pc = 4.25
Added TG parameter 00_Functions|03_chordDistSpanwise|02_RangeBased|chordShroud = 16
Added TG parameter 00_Functions|04_RatioDistSpanwise|02_RangeBased|ratioShroud = 0.3
Added TG parameter 00_Functions|03_chordDistSpanwise|02_RangeBased|chord20pc = 10
Added TG parameter 00_Functions|02_staggerDistSpanwise|02_RangeBased|staggerHub = 48.6
Added TG parameter 00_Functions|06_statorDist|01_CamberAngleDist|camberHub = 12
Added TG parameter 00_Functions|02_staggerDistSpanwise|02_RangeBased|stagger80pc = 64.25
Added TG parameter 00_Functions|03_chordDistSpanwise|02_RangeBased|chord80pc = 14
Added TG parameter 00_Functions|06_statorDist|01_CamberAngleDist|camberMid = 9.4
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posInt1_z = 0.25
Added TG parameter 00_Functions|05_thicknessDistSpanwise|01_RangeBased|thicknessMid = 0.06
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posInt2_z = -0.15
Added TG parameter 00_Functions|05_thicknessDistSpanwise|01_RangeBased|thicknessHub = 0.1
Added TG parameter 00_Functions|05_thicknessDistSpanwise|01_RangeBased|thickness80pc = 0.04
Added TG parameter 00_Functions|01_camberDistSpanwise|02_RangeBased|camber20pc = 11.7
Added TG parameter 00_Functions|02_staggerDistSpanwise|02_RangeBased|stagger20pc = 51.8
Added TG parameter 00_Functions|05_thicknessDistSpanwise|01_RangeBased|thickness20pc = 0.08
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posShroud = 0.1
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt2 = 4
Added TG parameter 00_Functions|06_statorDist|01_CamberAngleDist|camber20pc = 11.7
Added TG parameter 00_Functions|NOB = 17
Added TG parameter 00_Functions|01_camberDistSpanwise|02_RangeBased|camberMid = 9.4
Added TG parameter 00_Functions|01_camberDistSpanwise|02_RangeBased|camberShroud = 1.67
Added TG parameter 00_Functions|01_camberDistSpanwise|02_RangeBased|camberHub = 12
Added TG parameter 00_Functions|06_statorDist|01_CamberAngleDist|camberShroud = 1.67
Added TG parameter 00_Functions|02_staggerDistSpanwise|02_RangeBased|staggerShroud = 67.25
Added TG parameter 00_Functions|04_RatioDistSpanwise|02_RangeBased|ratioMid = 0.5
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt1 = 2
Added TG parameter 00_Functions|04_RatioDistSpanwise|02_RangeBased|ratio20pc = 0.4
Added TG parameter 00_Functions|01_camberDistSpanwise|02_RangeBased|camber80pc = 4.25
Added TG parameter 00_Functions|03_chordDistSpanwise|02_RangeBased|chordMid = 12
Added TG parameter 02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|thetaShroud = -15
Added TG parameter 00_Functions|04_RatioDistSpanwise|02_RangeBased|ratio80pc = 0.4
Added TG parameter 00_Functions|05_thicknessDistSpanwise|01_RangeBased|thicknessShroud = 0.03
end of sync_TG_parameters_from_lines
os_ver: Win64
ProjectPath....D:\Raj_Projects\4225-001183_RY40HPLB04_Blower_700CFM\BLADE DESIGN
Copied CAESES project D:\Raj_Projects\4225-001183_RY40HPLB04_Blower_700CFM\BLADE DESIGN\700BlowerBlade.cdb to D:\Raj_Projects\4225-001183_RY40HPLB04_Blower_700CFM\WORKBENCH\Blower700cfm_files\dp0\C_TG_GEO\ACT\700BlowerBlade.cdb
No replacement for TG param '|00_Functions|01_camberDistSpanwise|02_RangeBased|camber20pc'
No replacement for TG param '|00_Functions|01_camberDistSpanwise|02_RangeBased|camber80pc'
No replacement for TG param '|00_Functions|01_camberDistSpanwise|02_RangeBased|camberHub'
No replacement for TG param '|00_Functions|01_camberDistSpanwise|02_RangeBased|camberMid'
No replacement for TG param '|00_Functions|01_camberDistSpanwise|02_RangeBased|camberShroud'
No replacement for TG param '|00_Functions|02_staggerDistSpanwise|02_RangeBased|stagger20pc'
No replacement for TG param '|00_Functions|02_staggerDistSpanwise|02_RangeBased|stagger80pc'
No replacement for TG param '|00_Functions|02_staggerDistSpanwise|02_RangeBased|staggerHub'
No replacement for TG param '|00_Functions|02_staggerDistSpanwise|02_RangeBased|staggerMid'
No replacement for TG param '|00_Functions|02_staggerDistSpanwise|02_RangeBased|staggerShroud'
No replacement for TG param '|00_Functions|03_chordDistSpanwise|02_RangeBased|chord20pc'
No replacement for TG param '|00_Functions|03_chordDistSpanwise|02_RangeBased|chord80pc'
No replacement for TG param '|00_Functions|03_chordDistSpanwise|02_RangeBased|chordHub'
No replacement for TG param '|00_Functions|03_chordDistSpanwise|02_RangeBased|chordMid'
No replacement for TG param '|00_Functions|03_chordDistSpanwise|02_RangeBased|chordShroud'
No replacement for TG param '|00_Functions|04_RatioDistSpanwise|02_RangeBased|ratio20pc'
No replacement for TG param '|00_Functions|04_RatioDistSpanwise|02_RangeBased|ratio80pc'
No replacement for TG param '|00_Functions|04_RatioDistSpanwise|02_RangeBased|ratioHub'
No replacement for TG param '|00_Functions|04_RatioDistSpanwise|02_RangeBased|ratioMid'
No replacement for TG param '|00_Functions|04_RatioDistSpanwise|02_RangeBased|ratioShroud'
No replacement for TG param '|00_Functions|05_thicknessDistSpanwise|01_RangeBased|thickness20pc'
No replacement for TG param '|00_Functions|05_thicknessDistSpanwise|01_RangeBased|thickness80pc'
No replacement for TG param '|00_Functions|05_thicknessDistSpanwise|01_RangeBased|thicknessHub'
No replacement for TG param '|00_Functions|05_thicknessDistSpanwise|01_RangeBased|thicknessMid'
No replacement for TG param '|00_Functions|05_thicknessDistSpanwise|01_RangeBased|thicknessShroud'
No replacement for TG param '|00_Functions|06_statorDist|01_CamberAngleDist|camber20pc'
No replacement for TG param '|00_Functions|06_statorDist|01_CamberAngleDist|camber80pc'
No replacement for TG param '|00_Functions|06_statorDist|01_CamberAngleDist|camberHub'
No replacement for TG param '|00_Functions|06_statorDist|01_CamberAngleDist|camberMid'
No replacement for TG param '|00_Functions|06_statorDist|01_CamberAngleDist|camberShroud'
No replacement for TG param '|00_Functions|NOB'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posHub'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posInt1_z'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posInt2_z'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|posShroud'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt1'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|thetaInt2'
No replacement for TG param '|02_BladeDesign|AxialFan|BladedComponent1|MeridionalContours|04_leadingEdge|thetaShroud'
File "C:\Users\raj.dave\AppData\Roaming\Ansys\v252\ACT\extensions\CAESES_Workbench_App\turbo.py", line 276, in update_TG
Exception: Expected CAESES output at D:\Raj_Projects\4225-001183_RY40HPLB04_Blower_700CFM\WORKBENCH\Blower700cfm_files\dp0\C_TG_GEO\ACT\700BlowerBlade\manual_results\baseline\input
WebPage: file:///C:\Program Files\ANSYS Inc\v252\Addins\ACT\html\gridpanel.html?ACTPort=49367&ACTSocketName=Log
I am using CAESES 5.3.8 and v3 of CAESES_Workbench_App
Please suggest a workaround for this issue.
7 minutes ago, Raj Dave said:
Hi All,
Extensions Log File
getProcessName
getProcessName
getProcessName
getProcessName
getProcessName
counterTG = 0
counter = 1
os_ver: Win64
Follow up to the post.
I tested v3 of the workbench app in a project where I successfully exported turbogrid files with v2 of the app, and here are the log files from it.
Extensions Log File
1/26/2026 1:29:15 PM
Initialize ExtensionManager
List of running applications:
- Project
The CAESES extension saved in this project will be upgraded from version 2.0 to 3.0. If you save the project, the change will be permanent. You can avoid it by closing the project, installing the older version, and reopening the project.
Starting Python script engine version 2.7.0.40 for extension CAESES.
Extension CAESES loaded for context Project.
Starting Python script engine version 2.7.0.40 for extension EnSight Forte.
Extension EnSight Forte loaded for context Project.
EnSight ext: Initializing EnSight extension...
EnSight ext: cei_home='C:\Program Files\ANSYS Inc\v252\CEI'
Starting Python script engine version 2.7.0.40 for extension optiSLang 25.2.2.
Extension optiSLang 25.2.2 loaded for context Project.
OSL_VERBOSE: 0
optiSLang - INFO - Initialize optiSLang Extension Version 25.2.0
optiSLang - INFO - Initialize optiSLang Extension Done
CALLING createParameterSet(task)
Error when invoking function 'createParameterSet'.
File "C:\Users\raj.dave\AppData\Roaming\Ansys\v252\ACT\extensions\CAESES_Workbench_App\parameters.py", line 5, in createParameterSet
AttributeError: 'NoneType' object has no attribute 'Value'
CALLING setFileFromGUI_TG(task)
valid file = D:\Raj_Projects\Sample700Blower_CAESES\GEOMETRY\Blower_700cfm\2025_08_05_700cfmScript.fsc
getProcessName id_tg_task2 1 getProcessName
task.Name at getProcessName= id_tg_task2 1
Geom_comp_name at getProcessName= id_tg_task2 1
onbeforetaskupdate id_tg_task2 1
getProcessName
onbeforetaskcreation id_tg_task2 1
getProcessName
getProcessName
getProcessName
getProcessName
counterTG = 0
counter = 2
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|01_camber|01_angleDistributionHub|angle1 = -14.82
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|02_angleDistributionShroud|angle1 = 67.003
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|02_angleDistributionShroud|angle2 = 64
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|02_angleDistributionShroud|angle3 = 62.3786
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|01_angleDistributionHub|angle2 = 46
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th4 = 1
Added TG parameter 00_Functions|rotor_stator_distance = 20
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|03_edgeDefinition1|ellipseFactor2 = 2
Added TG parameter 01_Turbo|700cfm|rotor|MeridionalContours|04_leadingEdge|thetaInt2 = 0
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|03_edgeDefinition1|ellipseFactor1 = 2.5
Added TG parameter 01_Turbo|700cfm|rotor|MeridionalContours|04_leadingEdge|thetaInt1 = 0
Added TG parameter 01_Turbo|700cfm|rotor|MeridionalContours|04_leadingEdge|thetaShroud = 0
Added TG parameter 00_Functions|stator_functions|NOB_stator = 11
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th4 = 2
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th1 = 1.25
Added TG parameter 01_Turbo|700cfm|stator|MeridionalContours|01_leadingEdge|thetaInt1 = 0
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th1 = 2
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th1 = 2
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th3 = 2.25
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th2 = 2.5
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th4 = 2
Added TG parameter 01_Turbo|700cfm|stator|MeridionalContours|01_leadingEdge|thetaInt2 = 0
Added TG parameter 01_Turbo|700cfm|rotor|MeridionalContours|05_trailingEdge|dist1 = 2.5
Added TG parameter 00_Functions|rotor_functions|rBladeLenShroud = 14
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th3 = 1.25
Added TG parameter 01_Turbo|700cfm|rotor|MeridionalContours|05_trailingEdge|dist2 = 2.5
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|01_camber|02_angleDistributionShroud|angle2 = -12
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|01_camber|02_angleDistributionShroud|angle1 = -23.99
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|01_camber|03_angleDistribution_050|angle1 = -19.7342
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|01_camber|03_angleDistribution_050|angle2 = -10
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th2 = 2
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th4 = 2
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th2 = 2
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th3 = 2
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th1 = 2
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|01_angleDistributionHub|angle3 = 42.4096
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|03_edgeDefinition1|ellipseFactor1 = 2
Added TG parameter 00_Functions|rotor_functions|NOB_rotor = 7
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|03_edgeDefinition1|ellipseFactor2 = 2
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th2 = 1.5
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|01_camber|01_angleDistributionHub|angle2 = -7
Added TG parameter 00_Functions|rotor_functions|rBladeLenHub = 12
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|01_angleDistributionHub|angle1 = 49.6745
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|04_angleDistribution_050|angle2 = 58.2
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|04_angleDistribution_050|angle3 = 54.6247
Added TG parameter 01_Turbo|700cfm|rotor|rotor_blade|01_camber|04_angleDistribution_050|angle1 = 60.4952
Added TG parameter 01_Turbo|700cfm|stator|MeridionalContours|01_leadingEdge|thetaShroud = 0
Added TG parameter 01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th3 = 2
os_ver: Win64
ProjectPath....D:\Raj_Projects\4225-0xxxxx_Sample700Blower_CAESES\GEOMETRY
Error copying CAESES project: [Errno 2] Could not find a part of the path 'D:\Raj_Projects\4225-0xxxxx_Sample700Blower_CAESES\GEOMETRY\Blower_700cfm.cdb'.: D:\Raj_Projects\4225-0xxxxx_Sample700Blower_CAESES\GEOMETRY\Blower_700cfm.cdb
No replacement for TG param '|00_Functions|rotor_functions|NOB_rotor'
No replacement for TG param '|00_Functions|rotor_functions|rBladeLenHub'
No replacement for TG param '|00_Functions|rotor_functions|rBladeLenShroud'
No replacement for TG param '|00_Functions|rotor_stator_distance'
No replacement for TG param '|00_Functions|stator_functions|NOB_stator'
No replacement for TG param '|01_Turbo|700cfm|rotor|MeridionalContours|04_leadingEdge|thetaInt1'
No replacement for TG param '|01_Turbo|700cfm|rotor|MeridionalContours|04_leadingEdge|thetaInt2'
No replacement for TG param '|01_Turbo|700cfm|rotor|MeridionalContours|04_leadingEdge|thetaShroud'
No replacement for TG param '|01_Turbo|700cfm|rotor|MeridionalContours|05_trailingEdge|dist1'
No replacement for TG param '|01_Turbo|700cfm|rotor|MeridionalContours|05_trailingEdge|dist2'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|01_angleDistributionHub|angle1'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|01_angleDistributionHub|angle2'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|01_angleDistributionHub|angle3'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|02_angleDistributionShroud|angle1'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|02_angleDistributionShroud|angle2'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|02_angleDistributionShroud|angle3'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|04_angleDistribution_050|angle1'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|04_angleDistribution_050|angle2'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|01_camber|04_angleDistribution_050|angle3'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th1'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th2'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th3'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th4'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th1'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th2'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th3'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th4'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|03_edgeDefinition1|ellipseFactor1'
No replacement for TG param '|01_Turbo|700cfm|rotor|rotor_blade|03_edgeDefinition1|ellipseFactor2'
No replacement for TG param '|01_Turbo|700cfm|stator|MeridionalContours|01_leadingEdge|thetaInt1'
No replacement for TG param '|01_Turbo|700cfm|stator|MeridionalContours|01_leadingEdge|thetaInt2'
No replacement for TG param '|01_Turbo|700cfm|stator|MeridionalContours|01_leadingEdge|thetaShroud'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|01_camber|01_angleDistributionHub|angle1'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|01_camber|01_angleDistributionHub|angle2'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|01_camber|02_angleDistributionShroud|angle1'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|01_camber|02_angleDistributionShroud|angle2'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|01_camber|03_angleDistribution_050|angle1'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|01_camber|03_angleDistribution_050|angle2'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th1'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th2'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th3'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|01_thicknessDistributionHub|th4'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th1'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th2'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th3'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|02_thicknessDefinition1|02_thicknessDistributionShroud|th4'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|03_edgeDefinition1|ellipseFactor1'
No replacement for TG param '|01_Turbo|700cfm|stator|stator_blade|03_edgeDefinition1|ellipseFactor2'
Exception: Expected CAESES output at D:\Raj_Projects\Sample700Blower_CAESES\WORKBENCH\Blower700Sample_files\dp0\C_TG_GEO-1\ACT\Blower_700cfm\manual_results\baseline\input
I hope this is helpful.
