yuvraj 0 Report post Posted March 4 Hello CAESES I am trying to run a optimization module through the batch mode but not able to get specific keywords in the script file. Please guide me how to get specific keywords to run a sobol project in batch mode. It just export one single stl file which I mentioned but doesnt run the sobol. Thankyou trial.fsc Share this post Link to post Share on other sites
Carl Benz 5 Report post Posted March 4 Hi Yuvrai, The sobol you would like to run, needs to be called in the fsc script as well. Insert below the exports |<NameOfDesignEngine>.run() , e.g. |sobol1.run() . If you use the auto generation of fsc scripts in CAESES only the current state of the project will be implemented (1st open project file, 2nd set design variables). All actions you want to be done additionally you need to add into the script manually. But the lines added in the fsc are only called once. So if you want to export each design geometry of a design engine you need to use a software connector instead. best, Carl Share this post Link to post Share on other sites
yuvraj 0 Report post Posted March 5 Hello Carl Thankyou for the help. I am trying to deploy this on a cluster. It is much need to to create FSC file. I am currently using software Connector. Regards Yuvraj Share this post Link to post Share on other sites
