Furkan Tercanlı 0 Report post Posted January 5 Hello, I am studying piston shape optimization. I use Brent design engines to adjust the compression ratio, to keep it constant across all designs. However, some designs do not meet the CR constraint due to limitations of the Brent parameter and appear to be violated designs. I would like to avoid calculating violated designs.What should I do? Best Regards. Furkan Share this post Link to post Share on other sites
Mr. Mattia Brenner 6 Report post Posted January 5 Hi Furkan, at the computation object, there is an option to set a list of constraints. If one of these constraints is violated, the computation will not be executed for that design. Cheers, Mattia 1 Share this post Link to post Share on other sites
