AbodJabali
Cooling turbine blade
hello everyone i write to you as a beginner in this software and as student in my last semester where i work on my graduation project i have seen that this software could be very helpful to me especially with the difficulty to get a blade geometry with a profile which involves cooling passages and pins and fins i'm working currently on designing a blade which has different setups of pins and fins and cooling passages and from the explanation i saw on the website it seems that this could save me time by the ability to change the number of holes of angles of cooling passages...etc
i'm looking now for the shortest way to get such a blade profile where i could only import and work on like the picture attached to this topic, since i'm working on innovative mechanisms of heat transfer of turbine blades, im interested only in the part of the blade, the blade with root only because i'm going to apply different setup and meshes to obtain different results for my project
could anyone help me how to start with this or does anyone have a pre defined blade model where i could use in my project all the rights will be reserved for the person who can help because i'm only looking for ready designs because i don't so much time to learn the design fully on this software to be an advanced user
i hope i will hear an answer of you and that would be greatly appreciated
Hi there,
unfortunately the project you are referring to cannot be shared publicly. However, if you have a fixed blade geometry and want to investigate a variation of the cooling channels, a model can probably be set up quite easily. If you have something to work with, feel free to share it here and I'll take a look.
Heinrich
On 1/12/2024 at 3:13 PM, Mr. Heinrich von Zadow said:
Please see my two posts above...
I am sorry that I did not see the two posts you mentioned
