wh444 0 Report post Posted February 27, 2023 We can draw a number of curve and use FPolyCurve to fuse them into a "smooth" curve. An old post has discussed this question here. However, my model required a 2D "not smooth" enclosed curve made with three curves as below. It requires more than 2 intermediate points, therefore we can't use Multi Segmented Smooth Curve. And it's not a "smooth curve" therefore we abandoned the 2D interpolation curve. Therefore, I used poly curve, and results looks like this. To zoom in, we found flaws at corners. This flaws blocks me from moving forward in modeling. Get rid of the top line and the polyCurve seems work normal. My guess for the cause of the problem is the discontinuity, not a jump point but a removable discontinuous point. Please let me know if there is a way to deal with non-smooth multi-segmented curves. Any inputs are appreciated! WX Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted February 28, 2023 Could you try attaching the screen shots again? Share this post Link to post Share on other sites
wh444 0 Report post Posted February 28, 2023 10 hours ago, Mr. Heinrich von Zadow said: Could you try attaching the screen shots again? We can draw a number of curve and use FPolyCurve to fuse them into a "smooth" curve. An old post has discussed this question here. However, my model required a 2D "not smooth" enclosed curve made with three curves as below. It requires more than 2 intermediate points, therefore we can't use Multi Segmented Smooth Curve. And it's not a "smooth curve" therefore we abandoned the 2D interpolation curve. Therefore, I used poly curve, and results looks like this. To zoom in, we found flaws at top corners The flaws blocks me from moving forward in modeling. Get rid of the top line and the polyCurve seems work normal. My guess for the cause of the problem is the discontinuity, not a jump point but a removable discontinuous point. Please let me know if there is a way to deal with non-smooth multi-segmented curves. Any inputs are appreciated! WX Share this post Link to post Share on other sites
Mr. Heinrich von Zadow 12 Report post Posted February 28, 2023 Hi there, this is most likely a rendering issue and not related to the actual shape of the curve. Is there a particular reason why you are still using the CAESES4? If not, I strongly recommend you to upgrade. Apart from many many great new functionalities and a big difference in performance, also the rendering has improved significantly. Best regards, Heinrich Share this post Link to post Share on other sites
wh444 0 Report post Posted February 28, 2023 Thank you so much for you reply! Share this post Link to post Share on other sites
