Mr. Carlos Repolho 1 Report post Posted July 28, 2013 Hello Everyone I imported a RORO ship in IGES format to FF but instead of a single surface i got serveral trimmed surfaces due to the Rhinoceros modeling method applied in the previous design phase. I wanted simply to join this surfaces under the name Hull and use the feature for analysing the offset data. best regards Share this post Link to post Share on other sites
Karsten Wenzke 12 Report post Posted August 5, 2013 Hey Carlos, Did you solve your problem with the trimmed surfaces? Unfortunately we do not support trimmed surface import at the moment, but we are currently working hard tobe able to import trimmed surfaces. There is a workaround: export the roro-hull as .STLimport the stl to CAESES/FFWcreate a section group with FTrimesh of your hull as inputcreate offsets from section groupnow you should be able to analyse your hullPlease see the attached file with a small example. Regards, Karsten OffsetsFromSTL.fdb Share this post Link to post Share on other sites
