Xpan Wave Profil
3 replies to this topic
#1 Mr. Christian Christian
    Newbie
  • Pip
  • 6 posts
Posted 24 August 2018 - 11:03 PM
Hello,
I try to find out with the user manual as well as with the tutorial how can I show more then one Wave under the Plotviewer (XPAN Wave Profil)? Did anybody know how it works?
At the attachment i put an example how i want to have it. Thx for helping.
Kind regards
Chris
#2 Mr. Paulo Macedo
Mr. Paulo Macedo
    Newbie
  • Pip
  • 5 posts
Posted 27 August 2018 - 09:03 AM
Hi Christian,
In order to compare two wave profiles from XPAN computation do the following:
1 - Select the first design that you want to show in the table of results, click on show results button (a computer symbol with an eye in the middle);
2 - Go to the plot viewer and lock the design by clicking on the lock symbol upper left corner of the plot;
3 - Go to the design you want to compare with, select and also show the results (should be already triggered);
4 - Go back to the plot viewer and your two results should be there;
5 - Edit the plot settings so that you can distinguish between the designs.
Here is an example of two compared wave profiles: https://imgur.com/1rRPQ5A
Note the red lock button in the upper left corner.
Let us know if this solved your doubt.
Paulo
#3 Mr. Christian Christian
    Newbie
  • Pip
  • 6 posts
Posted 01 September 2018 - 10:42 PM
Hey Paulo,
thx for the explanation. Yes it works for two Wave Profils but if i want to compare more then two Waves?
How is it work then?
Kind Regards Chris
#4 Mr. Paulo Macedo
Mr. Paulo Macedo__0001
    Newbie
  • Pip
  • 2 posts
  • LocationÅlesund, Norway
Posted 05 September 2018 - 10:59 AM
Chris,
I am afraid it might not be possible.
It might be necessary to write a feature that plots them all together based on multiple shipflow results.
Maybe someone else knows another way for it.
Paulo
