Mr. Bikash Regmi 1 Report post Posted April 21, 2018 Which propeller design should be used while designing a Propeller type Axial Hydro Turbine? Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted April 23, 2018 Hi Bikash, I would probably use an approach using streamsections. See this video for some reference: best regards Carsten Share this post Link to post Share on other sites
Mr. Bikash Regmi 1 Report post Posted April 23, 2018 Hi Carsten, Correct me if I am wrong but I think impeller are used to impart energy to the fluid (i.e. increase enthalpy) and the blade profile that are to be used in turbine should be energy extracting one resulting in decrease in enthalpy of flowing fluid. So, what should be the modification in the impeller blade to make it a power generating one for turbine? Share this post Link to post Share on other sites
Mr. Paulo Macedo 0 Report post Posted April 23, 2018 Hi Bikash,It is very hard to know which type of turbine will be the best without runnning your own model into CFD programs.I would start by recent publications and current manufacturers of Axial Hydro Turbines.Some starting point would be:https://www.sciencedirect.com/science/article/pii/S1876610215005615https://www.sciencedirect.com/science/article/pii/0360544287901204From recent publications you can have an idea of what the state of the art ayial hydro turbines currently look like.After that you can connect your CFD code to CAESES and optimise your model.Carsten mentioned a very good tutorial to create your own geometry, a starting point to your future optimisations. Just adapt it to your needs along your study.Best regards,Paulo Macedo Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted April 25, 2018 Hi there, thanks Paulo for helping out with this interesting papers. The term impeller is just a general description for turbomachinery blades. Turbine blades are also some kind of impeller. With the method described in the video, you can create turbine-, compressor- & fan blades. The stream section, which is used to create the camber surface, allows you to set the flow angles (beta angles) or the wrap angles (theta angle). best regards Carsten Share this post Link to post Share on other sites
Mr. Bikash Regmi 1 Report post Posted April 26, 2018 Hi Paulo, That indeed helped me a lot. Those papers you mentioned, they have shown me the path in which I shall continue my work, so thank you for the help. Shout out to Carsten, your help is also appreciated. 1 Share this post Link to post Share on other sites
