Guest Mr. Watle Andreas Report post Posted May 5, 2017 Hi. I am running CAESES with shipflow in batch through matlab for an optimization purposes. The system is up and running, but I'm having trouble generating a text-file etc with some evaluations from shipflow. Now, the output folder only contains pictures of the pressure distribution, waveheights etc, but I want to generate a file containing Cw, Cwtwc Cf etc. Is this possible? Regards Andreas Share this post Link to post Share on other sites
Jörg 29 Report post Posted May 5, 2017 Hi Andreas, Just to give you an idea: Maybe you could write a feature definition that creates an ASCII file in the design directory, and which contains the values that you need. The following is taken from the documentation of Feature Definitions: // set up string for current design directory adding the name of the feature string workingDir(getDesignDir() + "/" + this.getName() + "/") // create a new path mkpath(workingDir) // open a file for writing FFile out(workingDir + "value.dat") out.openWrite() // write out the parameter value of myParam out.writeLine("value="+myParam.toString()) out.close() // now the external tool process myProcess("myTool.exe") myProcess.setWorkingDir(workingDir) myProcess.setArguments([workingDir+"value.dat"]) myProcess.run() // read the result FFile in(workingDir+"results.dat") in.openRead() // split the string by at least 1 whitespaces using regular expressions, // put single values into a list fobjectlist data(in.readLine().splitByRegExp("\s+")) double resultvalue(data.at(0).castTo(FString).toDouble()) // close the file in.close() Hope this helps,Joerg Share this post Link to post Share on other sites
