Ms. Yanxin Feng 1 Report post Posted March 17, 2017 Hi everyone, I got an alarm mark when I create the trimesh of the surface "fillet". Is there some way to remove mark? Otherwise there is an error in the simulation process like this: Any advice would be helpful. Thanks in advance. Have a nice weekend! Cheers,Yanxininnoship_manually_fs.fdbc Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted March 17, 2017 Hello Yanxin, I just had a brief view into the project. The error mark does not seem the be a problem. You will always have this error mark along an open edge of the trimesh. The trimesh looks fine. So I think you can continue. best regards Carsten Share this post Link to post Share on other sites
Ms. Yanxin Feng 1 Report post Posted March 20, 2017 Hello Yanxin, I just had a brief view into the project. The error mark does not seem the be a problem. You will always have this error mark along an open edge of the trimesh. The trimesh looks fine. So I think you can continue. best regards CarstenHi Carsten, Thanks for your reply. So if the trimesh was fine, then do you have some ideas about how to fixed the error when I run the calculation? BR,Yanxin Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted March 20, 2017 Hi Yanxin, ok it seems that the point [97.4,0,5.4] is at the bulb. You can try to increase the tesselation. best regards Carsten Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 5, 2017 Hi Yanxin, ok it seems that the point [97.4,0,5.4] is at the bulb. You can try to increase the tesselation. best regards CarstenHI Carsten, i have the same problem of the alarm mark. i have a tutorial about this work to do patch divided for KCS ship stern valley, may i ask how to do patch divide? Cheers, Lexi. Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted April 6, 2017 Hi Lexi, If I understand you correctly, I can split a patch surface with an imagesurface. Just restrict the u- or v- domain. best regards Carsten Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 6, 2017 Hi Lexi, If I understand you correctly, I can split a patch surface with an imagesurface. Just restrict the u- or v- domain. best regards Carsten can you see the picture p1 and p2?if i use image surface, the surface boarder is parallel to the original surface. i want to have edges like picture.1 .Cheers,Lexi. Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 6, 2017 Hi Lexi, If I understand you correctly, I can split a patch surface with an imagesurface. Just restrict the u- or v- domain. best regards CarstenMy picture failed to be uploaded , please see the link of PPT.https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwiW1-Pbuo_TAhWk5YMKHYCQAMcQFggxMAI&url=http%3A%2F%2Fmdx2.plm.automation.siemens.com%2Fsites%2Fdefault%2Ffiles%2FPresentation%2FFRIENDSHIP-Framework_STARCCM%252B.pdf&usg=AFQjCNG0Mu_NpVp0Gi-qOwSWdauHwRxi-g&sig2=zNPAJ9hwZFb1Y_34sc46cQCheers,Lexi. Share this post Link to post Share on other sites
Mr. Carsten Fuetterer 9 Report post Posted April 6, 2017 Hi Lexi, I don't know to which picture you are referning in the document. You can also trim surfaces with the help of subsurfaces or Breps using Projections. best regards Carsten Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 6, 2017 Hi Lexi, I don't know to which picture you are referning in the document. You can also trim surfaces with the help of subsurfaces or Breps using Projections. best regards CarstenThanks, i am really sorry, it is page 13/46.CheersLeix. Share this post Link to post Share on other sites
Ms. lexi wang__0001 0 Report post Posted April 6, 2017 Hi Lexi, I don't know to which picture you are referning in the document. You can also trim surfaces with the help of subsurfaces or Breps using Projections. best regards CarstenThanks, i have got the patch divide.Cheers,Lexi. Share this post Link to post Share on other sites
