Mr. Neukam Johannes 0 Report post Posted May 13, 2016 Hello, I defined a result value and can use the parameter for evaluation. But where can I set, whether dakota shall optimize for lower or higher values? After running a batch of optimizations with Dakota-Soga I can see, that I probably have not enough evaluations. Therefore I would like to keep the optimization going, but I can only use the run as a result pool. I could not find that term in the tutorials. What is it? kind regards, Johannes Share this post Link to post Share on other sites
Stefan Wunderlich 6 Report post Posted May 13, 2016 Hi Johannes, I am afraid, there is currently no inbuild option to optimize for max value.I would simpla invert the value of the evaluation (probably in an additional parameter) if I wanted to head for max value (value * -1).We should really consider to do this internally and give the user a "clickable" option. You are right, somehow the documentation for the result pool got lost on the road (not good).Using a previous run as result pool means that a design created within the current run that has the same design variable values like a design in the result pool will not be evaluated but only linked to the result pool design in order to reduce computation time. So it is a recommended option. I hope that helps. Cheers,Stefan Share this post Link to post Share on other sites
Mr. Neukam Johannes 0 Report post Posted May 13, 2016 Thank you for the quick reply :-) Share this post Link to post Share on other sites
Mr. Carlo Pasquinucci 1 Report post Posted May 13, 2016 Hi Johannes, CAESES try always to find the minimum. The suggest workaround from Stefan in correct. Theoretically is possible to change the input file for Dakota to force to find the max and not the min. I really suggest you to use the Stefan method if you are not expert. Otherwise, you can write sense max , in the response field in the Dakota template. Cheers,Carlo Share this post Link to post Share on other sites
