Sign in to follow this
Mr. Felix Balzar
Creating a Lines Plan
Dear supporters,
I wanted to create a lines plan for my hull via SurfaceGroupLinesPlan. After submitting the necessary geometrical informations a error message appeared, stating:
*** INFO Command Parser : Invalid default value [Default value for argument paper (Value: A0) is invalid, assigning NULL.]
There is no item to select in the respective dropdown menu. I can check the box ''Allow Expression'' in the Tab ''Arguments'' but I don't think it has an impact on this.
Where can I assign a proper value to ''paper''? Is there something broken with the installation?
Thanks for your help,
Felix
Hi Felix,
in order to run this feature you have to create a 2DScene first. You can do that by going to View > New > 2D Window Setup.
This is also mentioned in the feature description.
Best regards
Matthias
Thank you Matthias, you're right, I could have read it more carefully.
I successed in creating the 2D Window and the feature.
After running it, CAESES displayed the error
*** INFO FDoubleIntCast : Cast warning: [fraction of value skipped]
I used values such as 0.35, double with a point as separator.
The lines plan is not yet displayed in the 2D Window.
Hi Felix,
for which value you got this error? Is it possible to share your project with me, either here in the forum or via email (maasch@friendship-systems.com).
Best regards
Matthias
