Mr. Bora Oendin 0 Report post Posted April 4, 2013 Hello, is there any possibility to export Offset-Curves to a DXF-Format? I would like to couple the FRAMEWORK with a seakeeping tool, which only reads the hullshape as a DXF-File containing hull-sections as polylines. Regards Share this post Link to post Share on other sites
Jörg 29 Report post Posted April 4, 2013 Hi Bora, Unfortunately, DXF export is not supported so far. A quick workaround might be a feature which writes out the polyline data as required. CheersJoerg Share this post Link to post Share on other sites
Mr. Carlos Repolho 1 Report post Posted May 11, 2013 Hello! I actually exported dxf section contours from rhino. The problem was that i couldn't then join them together, they come has broken curves. regards Share this post Link to post Share on other sites
Jörg 29 Report post Posted May 13, 2013 Hi Carlos, Do you have an example file for us where this happens? Joerg Share this post Link to post Share on other sites
Mr. Carlos Repolho 1 Report post Posted July 25, 2013 Sorry for the delay! here it goes. The sections seem ok, the only problema is that they are composed of segments. regardsyacht.fdbc.fdb Share this post Link to post Share on other sites
