Sign in to follow this
Ms. Dimitrios Makris
Merging Projects
Hi Makris
Copy and paste could be the way.
Suppose we have two different projects A and B and a new empty N.
- Open A and N
  • Copy all Feature Definitions from A and past in N.
  • Copy everything under baseline from A and past in N
  • Copy all Configuration from A and past in N
  • Copy all Constraints from A and past in N
  • Copy all Computations from A and past in N.
- Close A and open B.
- Do the same things with B and N.
Then you could have it.
Well... I am not sure 100% but...more than 95%...... :) .
Regards
Daehwan.
Hi Daehwan,
I cannot find a way to open two different projects simultaneously. But that is no more a problem because I found another way to proceed with one of the projects, with no need of the other one. Thank you very much.
Makris
