Tobias Stein
How do I handle Error messages when starting the CAESES
The startup log shows single system entries during the startup process. It can be found for Windows users under following path:
C:\Users\YOURNAME\AppData\Roaming\friendship\etc\log\startuplog.html
If problems occure errors entries will be written in the startup log.
For example: licence file problems can be determined by entries in this startup log
IMPORTANT: When contacting the FRIENDSHIP Support, this startuplog has to be attached. If you are using a node-locked license, you have to send the fslicense.dat, too.
