Mr. Tonci Pirovic 3 Report post Posted May 26, 2014 Hi,I'm trying to model a tentative tank configuration and so far I've managed to simulate movement of the fluid level more or less as I wanted ( only in a wireframe though)...Geometry of the fluid free surface is quite interesting. It's self-adaptive to number of tank sides at current elevation...But to complete the model I need to answer few more questions :huh: 1) how to model a solid below the fluid level? The idea is to track the current percent of tank filled in relation to full tank capacity.2) is there a way to avoid warning masage for projection curve |tank|fluid|level|outerLevel|outerLvl2 , which cannot be generated above a certain point? thanks in advance,Tonci tank filling.fdbc Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted May 27, 2014 Hi Tonci, Very nice example, thank you! I have added two solids. One based on the full tank, one cut at the z-coordinate of your reference point "anchor". The solids can tell you the volume. The bar chart shows you the relative filling grade and the volume itself. CheersClaustankFillingWithSolid.fdbc Share this post Link to post Share on other sites
Mr. Tonci Pirovic 3 Report post Posted May 27, 2014 Hi Claus, I've encountered some difficulties reading the file...certain functionality seems to be missing in version I have ( FProjectionCurveObsolete ) so model is only partly evaluated...But anyway, I was able to check new TriMesh definitions... Whow! This postprocessing TriMesh functions are really, really powerful ! Thank you very much for these insights! Tonci Share this post Link to post Share on other sites
Mr. Claus Abt 14 Report post Posted May 28, 2014 Sorry Tonci,I have worked with the new release and we have replaced the projectionCurve and kept the old one as FProjectionCurveObsolete. Happy to see examples like the one you provided. CheersClaus Share this post Link to post Share on other sites
