Yukai 0 Report post Posted October 31, 2023 Hello! I have a problem connecting to Openfoam! I imported all the system, constant, 0 and other files in the original CASE folder into CAESES, and then imported Allrun as well. I would like to ask if the Allrun path needs to be set to the original CASE folder? Because after CAESES starts executing, it will copy the imported data and create a new folder, which also contains Allrun. I want to know where my path should be set? There is also the model export part. Do I need to export the model STL file in CAESES first and put it in the original constant folder and then execute openfoam through the CAESES interface? The problem I encountered is that if there is no STL file in the original folder, simulation cannot be performed. I want to know how I can let openfoam read my model on CAESES. I have modified the STL reading path in the opemfoam-related files. For example: change the stl file read in surfaceFeaturesDict to <entry>Exports|hull</entry>.stl Thanks for your help!! Best Regards Share this post Link to post Share on other sites
